Thread: Car and Amp Ohm compatibilty
Results 1 to 20 of 20
  1. #1 Car and Amp Ohm compatibilty
    Jul 2010
    Northwest Indiana
    I understand the fact that Ohms are an important thing to consider with subs and amplifiers. I am a bit of a newb when it comes to these fancy numbers, so here's what i need help with.
    Subs:
    • 4-ohm total impedance
    • power handling: 500-1,000 watts RMS (2,000 watts peak power)
    Amplifier:
    • mono subwoofer amplifier
    • 500 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
    Now that's all of the information I could find for both on Crutchfield.com, the subs are Rockford Fosgate P3L-2X12 and the Amplifier is a Rockford Fosgate Prime R1000-1D. Just getting a second opinion on compatibility with both of those, making sure there's no possible chance of damaging subs/amp.
    Any expertise would be greatly appreciated.
  2. #2 Re: Car and Amp Ohm compatibilty
    Willoughby, Ohio
    ok here we go, those are dual voice coil (DVC) subs so its 4 ohms per sub and you are gettin two, each coil can handle 500 watts RMS or 1000 watts RMS per sub. the amp is 4 ohm stable and is good for 500 watts RMS or 2 ohm stable and good for 1000 watts RMS. SO if the coils on the subs are wired into series (8 ohm load per sub) and the subs wired to the amp in parallel, that would be a 4 ohm load to the amp. it wouldnt damage anything but you would be gettin only half the power out of your subs. i say get an amp that is good for 1000 watts at 1 ohm and that way you can wire the subs in parrallel (2 ohms per sub) and wire them to the amp parallel and you would get a 1 ohm load and get the full potention of your subs without damaging anything
  3. #3 Re: Car and Amp Ohm compatibilty
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    Quote Originally Posted by CTKGP09 View Post
    and if you did quite catch that^... look at this diagram for wiring Subwoofer Wiring Diagrams, Two 4 ohm Dual Voice Coil (DVC) Speakers
  4. #4 Re: Car and Amp Ohm compatibilty
    Jul 2010
    Northwest Indiana
    thanks for all that information. I appreciate it except, no offense most of it went in one ear and out then next, but ill remember this and I will look into it, any adive on how to wire subs parallel, is it the same as bridging?
  5. #5 Re: Car and Amp Ohm compatibilty
    Feb 2010
    Gilman IA
    Quote Originally Posted by nwigxp View Post
    cough posted a link about that exact question cough cough
  6. #6 Re: Car and Amp Ohm compatibilty
    Jul 2010
    Northwest Indiana
    Quote Originally Posted by chickenfried View Post
    Sorry chickenfried, overlooked that, thanks
  7. #7 Re: Car and Amp Ohm compatibilty
    If you ran it on one coil i'm willing to bet you could still give it more than 500 W RMS based on the fact that they're right beside each other so the heat would transfer between the two....
    But the rest you've got right.
    summary: look for an amp that will put out 1000 watts RMS at 1 Ohm
  8. #8 Re: Car and Amp Ohm compatibilty
    Feb 2010
    Gilman IA
    if in a sealed box wouldnt giving each sub a chamber help with this? i mean i know most sealed boxes are made in one chamber but its not that hards to add a peice of mdf in the middle. just curioius cuz i have never thought about it like the way you just said it.
  9. #9 Re: Car and Amp Ohm compatibilty
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    i'd say more than 1kw rms that way you can turn down the amp and also help with independence rise
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  10. #10 Re: Car and Amp Ohm compatibilty
    The only thing that would do is let you keep running one sub optimally if you blew the other.
  11. #11 Re: Car and Amp Ohm compatibilty
    Feb 2010
    Gilman IA
    good to know
  12. #12 Re: Car and Amp Ohm compatibilty
    Feb 2009
    Virginia
    If you ran stereo subs it would allow for that too
    11 is louder than 10!
  13. #13 Re: Car and Amp Ohm compatibilty
    like you can have "stereo" subs in a car
  14. #14 Re: Car and Amp Ohm compatibilty
    Feb 2009
    Virginia
    it's been done before. I would think install is crucial since cancellation could easily occur?
  15. #15 Re: Car and Amp Ohm compatibilty
    Arizona
    '00 GT- nothing special
  16. #16 Re: Car and Amp Ohm compatibilty
    How would that benefit you when most people end up with the subs in the trunk?
    Most anything crossed over at 40 Hz or lower (where subs should be crossed over) is impossible to localize.
    Again, get a proper mid-bass solution.
  17. #17 Re: Car and Amp Ohm compatibilty
    Feb 2009
    Virginia
    Some people run subs as high as 200hz too...
    As long as install is correct there shouldn't be any issues. When you get to very loud volumes a proper 3-way can help tremendously with power handling requirements. However...in a car environment, 3-way + sub is a b. Since the subs are so close, tuning and transparency are a must, but you could set up a two way + sub to make up the difference for the lack of a mid-bass.
    The basic rule in 2-way is that you HAVE to sacrifice somewhere...either mid-range or bass. You can't have the best of both worlds.
  18. #18 Re: Car and Amp Ohm compatibilty
    second order crossover for subs at 80 Hz still leaves too much sound coming from the sub at 150 Hz.
    Sounds like its coming from behind you.
    4 way is the only way to get loud in a car.
  19. #19 Re: Car and Amp Ohm compatibilty
    Feb 2009
    Virginia
    I don't know what you do but my sub compliments nicely I play with my sub between second order and 4th order as high as 160hz and as low as 80hz (trying to deal with a resonance issue in the doors). It always sounds like it's coming from in the front of my dash as if the mids are creating the bass. I keep the rear seats up too.
    But we also have very different listening styles Sometimes you can feel your hat moving tho
    EDIT: The subs are also facing the rear seat so you can see them when folding down This helped tremendously with mid-bass transparency. However, facing the rear would be fine if I stayed at 80hz or lower.
  20. #20 Re: Car and Amp Ohm compatibilty
    Cant fit an 18 facing any direction but up
