Thread: Car and Amp Ohm compatibilty
Results 1 to 20 of 20
  1. #1 Re: Car and Amp Ohm compatibilty
    second order crossover for subs at 80 Hz still leaves too much sound coming from the sub at 150 Hz.
    Sounds like its coming from behind you.
    4 way is the only way to get loud in a car.
  2. #2 Re: Car and Amp Ohm compatibilty
    Feb 2009
    Virginia
    I don't know what you do but my sub compliments nicely I play with my sub between second order and 4th order as high as 160hz and as low as 80hz (trying to deal with a resonance issue in the doors). It always sounds like it's coming from in the front of my dash as if the mids are creating the bass. I keep the rear seats up too.
    But we also have very different listening styles Sometimes you can feel your hat moving tho
    EDIT: The subs are also facing the rear seat so you can see them when folding down This helped tremendously with mid-bass transparency. However, facing the rear would be fine if I stayed at 80hz or lower.
    11 is louder than 10!
