Thread: 2007 GT rear speakers install
Results 1 to 9 of 9
  1. #1 Re: 2007 GT rear speakers install
    Apr 2011
    Iowa
    Quote Originally Posted by reallyfast1 View Post
    yup u take off the bottom part of the seat 1st, pull nobs under neath the seat.. after that grab a rachet take out the seat belts, fold seats down 4 screws across the back support hold in the top part take them out.. then u should be able to get to the rear deck, u have to take this off and it gives u access to the rear speakers!!
    do u have a deck in your car? if not then when u put in ur rears u will have to sets of wires going to each speaker.. 1 for the mid, 1 for the tweet. i dont think u can use both for 1 speaker, so if u want u can get a set of tweeters and wire them to the other set of wires ur not using!! here's the color codes for the monsoon system with amp in trunk, dont know about other systems, but this is what mine is in a 06 GT! THIS SHOULD HELP!!
    Radio 12v orange + radio harness
    Radio Ground black/white - radio harness
    Radio Ignition (Class 2 Serial Data)
    Radio Illumination gray (dimmer) + radio harness
    Factory Amp Turn-on same as power antenna wire
    Power Antenna purple + radio harness
    LF Speaker +/- tan - gray +,- radio harness or amplifier
    Notes: The amplifier is under the rear deck.
    RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
    LR Speaker +/- brown - yellow +,- radio harness or amplifier
    LR TWEETER +/- green/black - blue/white
    RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
    RR TWEETER+/- green/black - blue/white
    I followed the steps above but after removing the 4 bolts holding the back support in place, the back support is still attached at both sides by small pieces of seat back that stayed in place when dropping the seat backs..Is that back support piece suppose to come off? It is keeping me from getting the back deck off..
  2. #2 Re: 2007 GT rear speakers install
    Pennsylvania
    Try my handy-dandy tutorial, lad!
  1. new to site, removing rear seat in a 2007
    By JoeC9107 in forum General Tech Discussion
    Last Post: 12-19-2010, 09:23 PM
  2. Rear speakers
    By josemolina2008 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2010, 02:21 PM
  3. Rear speakers
    By Farmboy87 in forum Audio, Security & Visual Electronics
    Last Post: 07-19-2009, 10:09 AM
  4. How to install new front speakers on a 97 Pontiac Grand Prix?
    By GothTP in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2009, 07:59 AM
  5. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
