yup u take off the bottom part of the seat 1st, pull nobs under neath the seat.. after that grab a rachet take out the seat belts, fold seats down 4 screws across the back support hold in the top part take them out.. then u should be able to get to the rear deck, u have to take this off and it gives u access to the rear speakers!!
do u have a deck in your car? if not then when u put in ur rears u will have to sets of wires going to each speaker.. 1 for the mid, 1 for the tweet. i dont think u can use both for 1 speaker, so if u want u can get a set of tweeters and wire them to the other set of wires ur not using!! here's the color codes for the monsoon system with amp in trunk, dont know about other systems, but this is what mine is in a 06 GT! THIS SHOULD HELP!!
Radio 12v orange + radio harness
Radio Ground black/white - radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on same as power antenna wire
Power Antenna purple + radio harness
LF Speaker +/- tan - gray +,- radio harness or amplifier
Notes: The amplifier is under the rear deck.
RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
LR Speaker +/- brown - yellow +,- radio harness or amplifier
LR TWEETER +/- green/black - blue/white
RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
RR TWEETER+/- green/black - blue/white
