Thread: Amp Remote Wire
Results 1 to 20 of 20
  1. #1 Re: Amp Remote Wire
    Get the one linked above, should work.
    Can't give you local help
  2. #2 Re: Amp Remote Wire
    GT Level Member Xorbex's Avatar
    Canada
    Found this "in your pass kick panel there is a large group of wires, its the larger of the yellow ones that are there. will shut your amp off when you open your door" in another thread. Do you know if this works with 04+?
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  1. Need to know remote wire color
    By ljj in forum General Tech Discussion
    Last Post: 05-13-2010, 08:13 PM
  2. blue remote wire
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 11:30 PM
  3. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
  4. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  5. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
