Thread: amp remote wire question
Results 1 to 4 of 4
  1. #1 amp remote wire question
    Feb 2008
    So i just installed a new head unit (JVC KD-HDR50). I had a (Sony Xplod CDXGT520). i noticed that the plug in for the sony fit inside the back of the JVC so i just used that plug in. Everything works great but im not getting power to my amp. I grabbed my voltmeter and checked the amp its got power to the 12v the ground is solid but there is no power going to the blue wire at the amp. IS there supposed to be or not. There are no fuses for the blue wire it runs from the head unit direct to the back and then to the amp. I checked all of the fuses amp has 2 those are good and the main fuse under hood is good and has power. What did i do wrong? did i need to use the wires that came with the JVC even though everything works great>
    thanks for you help guys.
  2. #2 Re: amp remote wire question
    Milbank, South Dakota
    If all else fails you could run a manual switch to turn the amp on/off.
  3. #3 Re: amp remote wire question
    St. Louis Mo.
    You need a remote wire to trigger it to turn on when the headunit comes on. All amps that I know of have this little feature. You need to check the amp for a remote wire connection. And then you need to attach that wire to the remote wire off the headunit. That will trigger the amp to turn on and off with the hu.
    Let me clarify just incase, when I say remote wire, I dont mean the wired remote control for amp gain or anything like that. It is simply going to be a 16ga or similar small wire that will run from the rear of the HU to your amp. You just splice the ends, and attach one to the remote wire connection on the amp and the other attach to the remote wire on the hu. Simple
    James Shafer
    St. Louis MO
  4. #4 Re: amp remote wire question
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    in a pinch if you are not getting voltage on the remote wire you can wire it to the switched voltage wire (red) and if you get a bad pop go to radio shack and get a 100 ohm resistor and that will help with the pop and just put it inline
  1. What's this wire for?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 08:00 PM
  2. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  3. Fly by wire T/B???
    By AKGTP in forum General Tech Discussion
    Last Post: 01-30-2009, 11:36 PM
  4. Corolla spark plug wire change (general maint. question)
    By 04CompG in forum Off Topic Discussion
    Last Post: 09-16-2008, 03:21 PM
  5. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
