Thread: LED lights wiring
Results 1 to 6 of 6
  1. #1 LED lights wiring
    Eagan
    Okay, so here's my question.
    I have a flip switch installed so that i can choose to turn on or off these aftermarket interior lights in my car, my only problem is i have no idea how to hook it up correctly.
    The switch has three prongs
    1.)Supply
    2.)Accesory
    3.)Earth Ground
    How do i wire this, plus where would the positive and negatives wires of the lights run too?
    Please someone help
  2. #2 Re: LED lights wiring
    Willoughby, Ohio
    supply goes to a constant +12V supply like battery or fusebox hot
    acessory will go to the positive wires on the LEDs
    ground will go to a good chassis ground on the car along with the negative wires of the LEDS
  3. #3 Re: LED lights wiring
    Eagan
    thank you, this helps alot.
    i have 14 gauge automotive wire, they make a red one for positive and black for negative, does it matter if i use all red?
  4. #4 Re: LED lights wiring
    Eagan
    also on another matter how would i run the supply to the fusebox? does it need to go in through the back to run a fuse for it? if so how would i remove it?
    is there some kind of pictures or another?
  5. #5 Re: LED lights wiring
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    wire color is so you know what goes where you can use the same color but if you mess it up you are to blame not the wire
    you can get a fuse ad in from placed like autozone...
    theres a fuse box in your glove area theres a panel for it but its hard to say when the 97-03 is diff than a 04 and you didn't describe the car..
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  6. #6 Re: LED lights wiring
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    ALWAYS USE A FUSE!!! don't skip adding a fuse when you add your lights. If you need help with this project let me know because I am becoming a semi-expert on adding lights in cars now. I just recently put in lights in my ash tray and cup holder. I already have lights in my air vents and put in leds in the both the front and back where the feet wells are. If you need pictures I could send you some. On my switches that have three prongs the power one is going to be the one that u run from the fusebox (easier) or the battery itself. The opposite side should be the ground. The easiest way would be when you wire the ground to the switch to also combine the wires of the lights (ground wires) to the same prong. The middle one will be the power to the lights themselves.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  3. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
  4. Wiring LED grill lights!!! Please help
    By cojo in forum Visual/Body Modifications
    Last Post: 03-15-2009, 02:34 PM
