Thread: Amp Remote Wire
Results 1 to 20 of 20
  1. #1 Amp Remote Wire
    GT Level Member Xorbex's Avatar
    Canada
    Using my stock deck to add a sub using a LOC just wondering where the remote wire should be connected on the stock wiring harness (non bose)
    2005 GTP
    Sorry for the post in the wrong spot for the post but though id get a quicker response here
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Amp Remote Wire
    swift current,sask.
    Humm, If i was you I would just tap into something that has power in the ignition position.
  3. #3 Re: Amp Remote Wire
    Canada
    Yes but what wire in my harness does this thats the question really
  4. #4 Re: Amp Remote Wire
    swift current,sask.
    There should be a purple wire off of the deck if i'm not wrong that you can tap into. That should give you what you want.
  5. #5 Re: Amp Remote Wire
    Canada
    any idea what the purple controls and would this work for an 05
  6. #6 Re: Amp Remote Wire
    swift current,sask.
    It 's for the radio on signal, that is the only wire on the diagram that i can see will work. And yes it will work on an 05 that is what the diagram is for.
  7. #7 Re: Amp Remote Wire
    Canada
    Hey thx im in the middle of doing it..... Only getting 9.4v max there at the harness and amp.... light is on the amp so ill give it a shot
  8. #8 Re: Amp Remote Wire
    if you have onstar and dont use it there should be a pink wire in that harness that you can use.
  9. #9 Re: Amp Remote Wire
    Canada
    Got everything hooked up and sub doesnt work... exchanged low output converter for a diffferent one and still nothing. Not sure what Im doing wrong. Where should my LOC be getting power from? I have this http://www.futureshop.ca/en-CA/produ...1b8e845336en02 mayber im wiring it wrong???
  10. #10 Re: Amp Remote Wire
    swift current,sask.
    If the converter needs power, run it off of your remote wire. Did you make sure everything has power? Then just use your speaker wires and tap into them and hook those to the converter.
  11. #11 Re: Amp Remote Wire
    that seems mighty expensive.
    where exactly in canada do you live?
  12. #12 Re: Amp Remote Wire
    swift current,sask.
    Just get the pac interface, way cheaper and those are plug and play I beleive.
    Edit, here's the link
    http://www.pac-audio.com/productDeta...&CategoryID=28
  13. #13 Re: Amp Remote Wire
    Canada
    Yes it is
    Thunder Bay, ON
  14. #14 Re: Amp Remote Wire
    Get the one linked above, should work.
    Can't give you local help
  15. #15 Re: Amp Remote Wire
    Canada
    Found this "in your pass kick panel there is a large group of wires, its the larger of the yellow ones that are there. will shut your amp off when you open your door" in another thread. Do you know if this works with 04+?
  16. #16 Re: Amp Remote Wire
    Apr 2009
    Wausau, Wisconsin
    Sunroof wire in the fuse box.
  17. #17 Re: Amp Remote Wire
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by Stunt0Rider View Post
    this
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  18. #18 Re: Amp Remote Wire
    Canada
    Quote Originally Posted by whiney View Post
    Thx again I ended up getting it to work with the Re Q, I know it was stupid expensive but it works so I'm done with it. Just had to wire the Re Q properly.... First time I wired it I didnt read the instructions completly.
  19. #19 Re: Amp Remote Wire
    WI
    Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
    I just tried that, the RCA's work fine, but you have to tap a wire for the blue/white remote on.. It doesn't work by default.
    And as the OP said, I tried that purple wire, it's only hitting somewhere around 5 volts.. I have a post going too. I could tap that bundle going to the passenger door if it will work... Anyone have some insight?
    I have the exact same car...
  20. #20 Re: Amp Remote Wire
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    the orange is the 12v that i had to use!! but it is a constant 12v so u have to get a on/off switch to use this!! other than that ur LOC wires should be coming from the +/- of the rear mid! maybe try grounding ur LOC??
  1. Need to know remote wire color
    By ljj in forum General Tech Discussion
    Last Post: 05-13-2010, 08:13 PM
  2. blue remote wire
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 11:30 PM
  3. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
  4. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  5. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
