I am trying to wire up my MTX's and can't find a place to go through the firewall. I've looked for grommets on both sides and can't find much. Any info would be great.
pull up the carpet on the passenger side. Go from the inside out.
Well i did a number on that grommet. I taped the wire to a screwdriver and pushed but all it did was push that square piece in, so now I don't know what to do, still no wire through it.
Take the gromet apart cut a slit for the wire then push it threw.
Pry it up with a screw driver. The bottom art under the top is thing and you should be able to push threw that one. The top is thick and needs to be cut.
Okay I pulled the square piece out now I just need to poke through that thin piece underneath, Im just a little afraid of wrecking something. Thanks for the help man!
