Thread: Where to run power wire through firewall
Results 1 to 9 of 9
  1. #1 Where to run power wire through firewall
    SE Level Member Bueller's Avatar
    Nov 2009
    I am trying to wire up my MTX's and can't find a place to go through the firewall. I've looked for grommets on both sides and can't find much. Any info would be great.
  2. #2 Re: Where to run power wire through firewall
    Charles City, IA
    pull up the carpet on the passenger side. Go from the inside out.
    SMGPFC Two Nipple General
  3. #3 Re: Where to run power wire through firewall
    Nov 2009
    What do you mean inside out? I looked at that grommet, should I just put a little slice in it and try the coathanger trick?
  4. #4 Re: Where to run power wire through firewall
    Nov 2009
    Well i did a number on that grommet. I taped the wire to a screwdriver and pushed but all it did was push that square piece in, so now I don't know what to do, still no wire through it.
  5. #5 Re: Where to run power wire through firewall
    Charles City, IA
    Take the gromet apart cut a slit for the wire then push it threw.
  6. #6 Re: Where to run power wire through firewall
    Nov 2009
    Sorry for all the questions but how do I get that grommet apart? Kind of seems like a two piece thing to me.
  7. #7 Re: Where to run power wire through firewall
    Charles City, IA
    Pry it up with a screw driver. The bottom art under the top is thing and you should be able to push threw that one. The top is thick and needs to be cut.
  8. #8 Re: Where to run power wire through firewall
    Nov 2009
    Okay I pulled the square piece out now I just need to poke through that thin piece underneath, Im just a little afraid of wrecking something. Thanks for the help man!
  9. #9 Re: Where to run power wire through firewall
    Quote Originally Posted by Bueller View Post
    As long as you put the square piece back in, you'll be okay.
  1. Firewall Pass through
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2009, 05:06 PM
  2. firewall holes?
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 12:22 AM
  3. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  4. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
  5. Removing firewall grommet???
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-14-2008, 04:41 PM
