Thread: subs facing back seat
Results 1 to 12 of 12
  1. #1 Re: subs facing back seat
    Pointed towards the back will be the loudest but if you don't want to leave the pass through open then remove your 6x9s and open up that hole as much as possible otherwise you'll end up with a very poor bandpass box.
    Pointed forwards will have cancellation issues with the back of the trunk.
    THIS IS WHY SUBS SHOULD FIRE DIRECTLY INTO THE CABIN.
    Moving on...
    Perhaps your mids and highs are clearer because your sub isn't as loud?
    Also, you may have your sub crossover set too high. 50 Hz is the highest you can get without localization but 80 Hz is a decent compromise. If you have to run higher than that, you need a better midbass solution.
  2. #2 Re: subs facing back seat
    Feb 2009
    Virginia
    Moving on...
    The problem with a mid speaker is that it doesn't typically do mid bass and mid range extremely well. You pick your poison. It's either great as a mid range + ok as mid-bass or vice versa.
    11 is louder than 10!
  3. #3 Re: subs facing back seat
    Quote Originally Posted by I800C0LLECT View Post
    Or a woofer for 200 Hz and below and one for 200 Hz through 2-3 KHz placed AS CLOSE as possible to one another.
  1. Subs?
    By MakeitLouder97 in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2009, 05:35 PM
  2. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  3. how do you remove the back seat?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-26-2008, 08:11 PM
  4. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
