Thread: Rust behind and under back seat
Results 1 to 11 of 11
  1. #1 Rust behind and under back seat
    Louisville, KY
    What causes the rust behind the back seat on the GP? I took out my back seat on the 03 to see if I could fabricate a child restraint plate that is offered on the 2000 and newer cars for my 00 GP. When I did mine was covered in rust. Is this a known issue and what can I do to stop it.
    SE Level Member 01whitegtp's Avatar
    i have never heard of this, can you take a pic? Maybe your rear window is leaking water inside your car
    06 GXP - lowered, 20% tint
    Louisville, KY
    Moore, Oklahoma
    Dude, you have a water leak somewhere. My 99 GTP w/ 155k + being a former Michigan car doesn't look anything like that.
    Shawn W. Larsen
    Louisville, KY
    Mines an 03 with 51,000 from Kentucky. Doesn't snow here much but it rains all the damn time now and the humidity level is always high. Since I moved back from Colorado I miss the snow.
    Note: This car's never seen snow.
    Louisville, KY
    Think I'll take it out, clean it off, paint it, and see if it comes back.
    Bastard Reptile's Avatar
    Kansas City, MO
    It could also be the result of condensation on bare metal.
    I live here. UR LOSN's Avatar
    Rockford, IL
    sounds like a good idea! they make a paint that completely inhibits rust.
    more than likely from all the moisture in the air.
    SE Level Member hercman's Avatar
    Marietta, GA
    Here use this stuff works great
    POR-15 Inc.
    Saraland Alabama
    that is normal, humidity will do that (have seen many cars do that) a little spray paint and it should stop
    SE Level Member newfie's Avatar
    Toronto, Canada
    I wouldn't even bother painting it. Pull up the plastic or whatever covers the floor to make sure that there is no rust there (and confirm there is no leaks), and once you have your restraint made, put it in place and spray everything in some kind of rust inhibitor like Rust Check...it will be covered by the seats, condensation is most likely what caused this, so painting it would be a waste of time IMO.
    634whp 10.9@127mph '99 GTPT
    CT "lumpidy" Engine, Big Turbo, CT Trans, 3" Cut-out, Magnaflow's, AGX's, Eibach's, GMMP/BMR's, FBod Brakes, Xenon's, AE 077's, Kumho 711's
    http://www.cartuning.ca
