Thread: subs facing back seat
Results 1 to 12 of 12
  1. #1 subs facing back seat
    Jul 2008
    sumter,south carolina
    Ive ALWAYS had my subs facing to the rear of the trunk all my life... last week i took my box out to vacuum the trunk. 2 digital designs 1510's in a vented box on 500 watt memphis class D... well i decided to put them in facing the back seat... IMO the sound was better (with back console open) than the traditional facing to the rear... my highs and mids seemed to be more crisp and clear at loud volumes than with the traditional way. Trunk rattle almost completely went away also. anyone else have subs in this position?
    02 GTP with mods 05 GP for DD
  2. #2 Re: subs facing back seat
    SE Level Member Bueller's Avatar
    Nov 2009
    I tried this in my 2 dr Cavalier (2 MTX 12" 8000's and MTX1500 watt amp) and it definitely took the rattling away, but just never sounded right. I think not having the truck to bouce off of really killed the sound. I tried it a few times and always ended up putting them back towards the rear, but then again I know people with other setups facing forward and it sounded good.
  3. #3 Re: subs facing back seat
    May 2008
    I have a single sub in a sealed enclosure facing forward via the pass-through in the rear seat. There is no rattle, and to me it sounds better than it facing the rear of the car.
    In the near future, I will make a new box, but down-firing (sealed), and the opening only out into the cabin of the car via the pass-through.
    I only have 250 watts to my 8 inch sub, but it is a JL 8W7. Sometimes I want more (500w 10w7/10w6), but it compliments my 4x5.25 mids very well, You cant tell that it is behind you, the lows fill the entire cabin.
    I prefer SQ over SPL.
  4. #4 Re: subs facing back seat
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    no luck with mine faceing back still the loudest
  5. #5 Re: subs facing back seat
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    If u like the way it sounds leave it or try and seal it off from the trunk? but u might gain some extra db facing it to the trunk?
  6. #6 Re: subs facing back seat
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Point subs towards the greatest air volume. into the trunk, or into the cabin if you have pass thru or 60/40.... 2x12" P. Miller DVC's, one sealed, one in a 4th order band pass box and 500w RMS each. In a minivan. Say ow?
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  7. #7 Re: subs facing back seat
    Pointed towards the back will be the loudest but if you don't want to leave the pass through open then remove your 6x9s and open up that hole as much as possible otherwise you'll end up with a very poor bandpass box.
    Pointed forwards will have cancellation issues with the back of the trunk.
    THIS IS WHY SUBS SHOULD FIRE DIRECTLY INTO THE CABIN.
    Moving on...
    Perhaps your mids and highs are clearer because your sub isn't as loud?
    Also, you may have your sub crossover set too high. 50 Hz is the highest you can get without localization but 80 Hz is a decent compromise. If you have to run higher than that, you need a better midbass solution.
  8. #8 Re: subs facing back seat
    Feb 2009
    Virginia
    Moving on...
    The problem with a mid speaker is that it doesn't typically do mid bass and mid range extremely well. You pick your poison. It's either great as a mid range + ok as mid-bass or vice versa.
    11 is louder than 10!
  9. #9 Re: subs facing back seat
    Quote Originally Posted by I800C0LLECT View Post
    Or a woofer for 200 Hz and below and one for 200 Hz through 2-3 KHz placed AS CLOSE as possible to one another.
  10. #10 Re: subs facing back seat
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    i used to have my sub in the rear seat pass through facing the inside of the car. looked cool, and it fit perfect cuz of my box design. i ended up blowing that sub and went to my audio guy. he explained to me the physics of the sound waves and the idea is that you want them to bounce off as many surfaces as possible before they hit your ears. the way mine was set up, the sound waves had nothing to bounce off of. set of rear facing subs in a dynomatted trunk is the way to go. hands down.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  11. #11 Re: subs facing back seat
    Quote Originally Posted by 01gtspecial View Post
    LMFAO!@!#
    Maybe for bass.... Not for anything else. EVERY other speaker should have as few reflections as possible.
    Dynomatt? Thats going to do NOTHING other than make your trunk heavier. What you need to do is find a way to have the sub firing directly into the cabin with a somewhat airtight seal.
    If you don't want to do that, then find a way to make the trunk lid stay put. And no, dynomat doesnt do that. It just makes it heavier which lowers the resonant frequency of the trunk lid. Unless of course you use it to wedge between the top of the lid and the seal...
    The only thing that tames sound is cornings 707 and similar products. They turn sound into heat. THAT is how you handle resonances.
    That "pro" is just trying to sell you ****, not help you.
  12. #12 Re: subs facing back seat
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    personally i like them facing the trunk. its louder and thats what i like.
    im not into the crisp clean sounds. I like to hit hard.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. Subs?
    By MakeitLouder97 in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2009, 05:35 PM
  2. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  3. how do you remove the back seat?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-26-2008, 08:11 PM
  4. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
