Thread: 06 remote start problem
Results 1 to 17 of 17
  1. #1 Re: 06 remote start problem
    MO
    when I got my 06 the remote sensor was bad. could be a problem with the year, IDK. Also I was wondering about that tire pressure sensor, it'll only turn on when the tire gets low? won't give me a constant reading (which I don't get), how does it define low?
    <brandonl2000> LMAO D!!
  2. #2 Re: 06 remote start problem
    SE Level Member gpcustom's Avatar
    Indiana
    If both key fobs are having the same issue you can normally eliminate those as being the issue, I would start by check the car, you may want to do a FOB relearn, ( If you find a GOOD dealership they will normally give you the process or do the process for free). As for the tire pressure issue its possible the ABS connector in the back could have been disconnected or loose. This can cause the issue, Now normally this would throw a ABS light also but I have had this same issue with two different 03 models and the connector was loose ( just needed to be reseated ). If that doesnt work might want to look into a code check if possible.
    2004 Pontiac Grand Prix GT - 3800 Bored and Stroked
    Stage 1 wing - Custom Tuned PCM (PRJ)
    GXP Suspension (Full Swap) - Complete Custom Exhaust
  3. #3 Re: 06 remote start problem
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    does anyone have instructions on how to relearn a key fob?
    also the sensor that your talking about that could be unhooked. where is it?
    silver 2003 Grand Prix GT List is on it's way to be updated
  4. #4 Re: 06 remote start problem
    Indiana
    Quote Originally Posted by kjohnson View Post
    ABS Sensor is located in wheel hub, the connector you will normally find behind the wheel hub its easier to see once you take the rim off. You may want to disconnect the battery and then unplug all the ABS connectors and clean them if needed.
  1. Does my car have Remote Start? -- Solved
    By SyriusX in forum General Tech Discussion
    Last Post: 12-01-2010, 06:30 PM
  2. do I have a remote start or what??
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-24-2009, 02:28 PM
  3. Remote start on GP
    By Freebeer187 in forum General Tech Discussion
    Last Post: 04-12-2009, 07:30 PM
  4. DEI remote start
    By NightriderGT2000 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2009, 08:18 PM
