Dude... i gave him the same advice just said differently.
Hows this then, do it how 01GTP said.
No you said to use an accessory 12v wire, then the amp would have power the whole time the key is on. Run it with the remote wire so it is just on when the cd player is on. That way if you are having issues with the charging system you can turn the deck off and the amp will quit pulling power too.
