Thread: im in desperate need of help!
Results 1 to 20 of 20
  1. #1 Re: im in desperate need of help!
    SE Level Member walterg's Avatar
    webster mass
    true but i dont know wat tho cuz its already got its own amp so if i re wire i loose tht amp n then it wud jus be takin up space i know when i unplug the 4 speaker outlet from the bak of my stock radio they shut off so i know that they are the positives i jus dont got the moeny for the wiring n new speakers my buddy told me to try splicing them together positive to positive on the aftermarket radio n it should work but idk
  2. #2 Re: im in desperate need of help!
    webster mass
    negative is technically the ground
  3. #3 Re: im in desperate need of help!
    St. Louis Mo.
    Quote Originally Posted by walterg View Post
    You are right and you are wrong here. Why? Let me tell ya. Only your headunit might have actual ground wire that is hooked up to the car. Your speakers DO NOT have a ground wire that is hooked up to the chassis. Plain and simple. Big difference. When you say your speakers are grounded to the chassis, that is incorrect. YES obviously they are grounded via the speaker wire's negative ground wire, but they are NOT connected to the chassis in any way. The ground you speak of comes from the Headunit's ground.
    All you need to do is get the appropriate adapter to fit your car. Some adapters have the addons for OnStar to keep your chimes and the use of OnStar still available. I have an 03 GTX with OnStar, but i never used it so I went with the adapter that did not have the OnStar addon, which usually runs $150 bucks. My adapter only ran me about $30 bucks and i simply spliced the wires between the adapter and the new HU's wiring and it worked perfectly.
    I hope that clears some things up for ya.
    James Shafer
    St. Louis MO
