Thread: Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
Results 1 to 4 of 4
  1. #1 Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
    MN
    Also with the cd player I have to turn it on and off everytime how would you get around this. Also the keyless entrey problem. Any Ideas on how I can slove this problem. Also I have a 2007 Grand Prix.
  2. #2 Re: Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
    GT Level Member yulaw335's Avatar
    Michigan
    on the keyless entry you might have blown a fuse?
  3. #3 Re: Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
    St. Louis Mo.
    Moved to the correct section.
    I would agree with Yulaw on this one, i would check your fuse panel diagram and seek out the remote control fuse, there should be one named something to that affect. And if you cant find it? I would get a fuse tester from Autozone or ORielly's and check each fuse near the glove box.
    Did you use an aftermarket wiring kit to hook up your Stereo? I know the 04+ GPs are very sensitive to changing out the stereos cause a lot of the controls go through the factory head unit.
    Good Luck
    James Shafer
    St. Louis MO
  4. #4 Re: Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
    Donating Users Joe's Avatar
    Waterloo, IA
    If you have to turn it on and off every time you might of hooked the constant 12v(Yellow I believe) from the deck up to a switched 12v wire on the car. Take a DMM and see if you have 12v to the wire hooked to the yellow wire coming out of the deck with the car off.
    2000 Grand Prix GTP
    e: JTuckGTP@gmail.com
  1. Keyless remote entry
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2012, 03:00 PM
  2. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
  3. Remote Keyless Entry
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2009, 11:58 AM
  4. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
  5. Cruise dosen't work?
    By crywolf in forum General Tech Discussion
    Last Post: 11-13-2008, 01:03 PM
