Thread: Keyless remote entry
Results 1 to 17 of 17
  1. #1 Keyless remote entry
    the desert
    hi i recently bought a used keyless remote entry from ebay but when i follow the instructions that came with it and try to syncronize it with my car it doesnt work what shuld i do
  2. #2 Re: Keyless remote entry
    SE Level Member hinkaj02's Avatar
    fort wayne, Indiana
    i've had the same problem and was told that i'd have to go to a dealer to get it synchronized.
  3. #3 Re: Keyless remote entry
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Negative.
    Important note - you MUST program all of your keyless remotes when you do this - NOT JUST THE NEW ONE. You are in essence - changing the channel/remote address of the vehicle and remote, and your old remotes will not work.
    1) Get in car and close all doors.
    2) In the fuse panel - remove the "MALL PGM" fuse - do not lose this!
    3) Insert key and turn ignition to ACC position - you should hear the interior chime once
    4) Turn key to "off" and quickly back to ACC.
    5) Open and close the driver's door. You should hear 1 chime - this will indicate that the system has entered diagnostic mode.
    6) Press and hold both the lock and unlock buttons on the transmitter (key fob) - for approximately 15 seconds. You should hear a chime after 7 seconds, DO NOT RELEASE THE BUTTONS - continue to hold for a second chime.
    7) Repeat step 6 for each transmitter. (maximum of 4 can be programmed for each vehicle)
    8) If you're finished programming, turn ignition off.
    9) Replace “MALL PGM” fuse.
    10) Open Door(s).
    11) Test transmitters.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  4. #4 Re: Keyless remote entry
    Charles City, IA
    I currently do not keyless entry. Would I be able to buy a key fob and program it or would my car not be set up for it? If my car is not set up for it what is a good kit? Sorrry for the thread jack.
    SMGPFC Two Nipple General
  5. #5 Re: Keyless remote entry
    the desert
    the only problem i have is my car doesnt go to acc it doesnt work i got it to acc one time i never can do it it gets stuck
  6. #6 Re: Keyless remote entry
    If your car wasn't built with the 1SC option package - then you don't have RKE capability.
    -Swash
  7. #7 Re: Keyless remote entry
    the desert
    it worked it worked i tried my spare key and it works thanks for everything everybody
  8. #8 Re: Keyless remote entry
    Jan 2009
    Long Island
    Thanks to Swash for excellent help!
  9. #9 Re: Keyless remote entry
    Good deal - glad I could help.
    -Swash
  10. #10 Re: Keyless remote entry
    Aug 2008
    KCMO
    swash does this work for 04+ models?
  11. #11 Re: Keyless remote entry
    Quote Originally Posted by carl06GT View Post
    Yessir!
    -Swash
  12. #12 Re: Keyless remote entry
    SE Level Member sandite5's Avatar
    Tulsa, OK
    The only issue I've got is that my keyless range is crap! I've replaced the batteries in both Key fobs, but I receive the same result.
    I guess before I try and attack the receiver, I could try to reprogram both fobs in hopes that it might refresh the computer? , Who knows?
  13. #13 Re: Keyless remote entry
    Charles City, IA
    OK thanks
  14. #14 Re: Keyless remote entry
    Tulsa, OK
    Bah! The reprogramming of both the FOB's worked, but it didn't increase the range . I supposed I'll have to hunt for the elusive receiver box/antenna...
    Anyone know of an easy way to access it? (or even where it is?)
  15. #15 Re: Keyless remote entry
    Jan 2009
    Utica Missouri
    Bumping this info.. mine chimes 4 times... not one...
    Bunnell, FL
    The receiver is the silvery box behind the dic
    I'm a Sex Offender
    Jan 2009
    Utica Missouri
    Hey! Thanks I knew that just couldn't remember where it was lol. I took it out one time
  1. Remote Keyless Entry
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2009, 11:58 AM
  2. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
  3. Help with remote start/keyless entry
    By Red97GPGT in forum Audio, Security & Visual Electronics
    Last Post: 03-13-2009, 10:50 PM
  4. Did all 04 GP come standard with remote keyless entry
    By serenityacres in forum 04+ Specifics
    Last Post: 02-20-2009, 04:53 PM
  5. My keyless entry broke
    By biggmman in forum General Tech Discussion
    Last Post: 10-18-2008, 12:11 AM
