Thread: has anyone put speakers in the side paneling by the back seats?
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: has anyone put speakers in the side paneling by the back seats?
    Feb 2009
    Virginia
    ~2.81 V is what sensitivity should be measured at, its more comparable across different impedance drivers.
    isn't it 1watt/1meter @ 2.81v?
    I'm trying to learn speaker specs now. I know some manufacturer's sneak in 2watts@1meter.
    11 is louder than 10!
  2. #22 Re: has anyone put speakers in the side paneling by the back seats?
    Topeka, KS
    Quote Originally Posted by GeddyLee View Post
    Well Aplines are ok, the reference series I know little about. I personally went with Memphis Audio M Class speakers, both the 6.5in and 6x9s. Your factory speaker locations will always look stock given how they are hidden behind the door panels and rear deck cover, so no worries on messing that up
    But you are right, you want more high end (trebble) and mid range bass for the fronts and leave the bass in the back. That way you get a nice all around sound from them.
    You will probably have to do a little dremeling of the speaker holder, if they are anything like the 97-03 GPs. There will be a plastic holder that contains the factory 5in speaker. You will need to carefully dremel it out to mate with the larger 6.5in speaker, but its not a hard task to pull off and still keep things custom
    So you dremeled the stock mounts and got 6.5's to fit ? If so do you have any pics and did you have to take the stock grills off the door panels ? My front speakers are blown again and am needing to replace them Again! FTL! DON'T BUY AUDIOBAHN they are CRAP!
  3. #23 Re: has anyone put speakers in the side paneling by the back seats?
    Quote Originally Posted by rynoman03 View Post
    Going to be putting 8's in there... Gotta fit somehow.
    Quote Originally Posted by I800C0LLECT
    At 8 Ohms yes, at four Ohms 2.81 V is two watts. V=IR which is voltage = current times resistance. Solve for I and multiply by V to get watts (Power=IV). And then you'll see that the nominal impedance makes a big difference in the actual sensitivity and # of ways you can wire the driver up to your amp(s).
  4. #24 Re: has anyone put speakers in the side paneling by the back seats?
    Topeka, KS
    Your're gonna put 8's in the front ? Sweet! Show pics on how you do it. I bet that will sound really good! I wonder if you will have to redo your door panels though ?
  5. #25 Re: has anyone put speakers in the side paneling by the back seats?
    Will do! Probably won't happen till December.
  1. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  2. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  3. Bucket seats in the back?
    By basshead42 in forum General Tech Discussion
    Last Post: 03-22-2009, 08:12 PM
  4. how to remove the back speakers...
    By bb52190 in forum Off Topic Discussion
    Last Post: 10-09-2008, 07:47 PM
