CTKGP09
well i mean a switch in ur remote wire between ur amp and a 12V source but anyway if u are using a line output converter (which is wut u described) it is supposed to be spliced into the harness in the rear of the headunit...however if the car's speakers are amplified, the proper wires will not be there to splice into...so if u splice in to the wires goin into the speaker with reguard to left and right there should be no problem. u are only taking the audio signal from the head unit and converting it and sending it thru RCAs to ur amp...ive installed line output converters in to an amplified speakers before with no problem...
