You shouldnt need a switch. Because the sunroof only works when the key is on anyways. Even if its not there...lol
I believe Stunt0rider is talking about the only ones i know they sell. You use one per side left and right and its so you can hook up an amp wit the factory radio.As we all know it dont have rca hookups on it. You splice the pos and neg on each speaker the wire goes to a little square box which then allows you to hook up rca's. The factory amp either does 1 of 2 things puts to much power to the little Square box (S),or to the amps inputs. It then either shorts out (sends to safe mode)the amp or the cars factory amp. disconnect the rca's and see if the deck speakers still work if they do then thats the problem. If not, and you have both speakers spliced in its a posability you have the pos and neg's crossed at the splices and its shuting down the factory amp (sending to safe mode). And again it dont do it when the key is off because the factory amp or any other amp dont run full till without the alternator spinning.which is around 14.4 volts. with the key off it could be 12 volts or lower see what im sayin ?
