Is the key off when its doing that? If so mine does that to with my new head unit. Reason is the amp is drawing to much power btw im talking bout the factory amp again. Once you turn it up past a certain point the amp shuts down.it again has to do wit the volts. My addapters looked just like yours and did the same thing worked good for a while then just all of a sudden stopped.The max input wattage on those are 44watts peak.the factory amp may be around that and it weakend a connection inside of it.Thats the only thing i can come up with as to why it just all of a sudden stops working.in the back of your radio the wires are thereif its between a 97-2002 i know for sure they are. search the internet as to which colors the ones u need to splice are and splice it in,and run the rcas to the back.The site you find should also tell you how to get the factory radio out to.which isnt that hard really.and your problem will be solved,and you wont be running your addapter at its max input range either. Trust me man ..try it and you'll be bumppin in no time wit no cut outs.
