Thread: Crimping Large Wires
Results 1 to 8 of 8
  1. #1 Crimping Large Wires
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    So after running my power and RCA wires today for my new system, i have come to a stand still trying to figure out how to crimp these wires!
    The wires are 4 gauge, and all my wire crimpers/stripeprs stop at 8 or 10 gauge, and i havent seen any in stores either.
    What does everyone use to crimp their wires? Vice grips? C clamps?
    Looking for something professional(ish) and efficient, no hammers please
  2. #2 Re: Crimping Large Wires
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    1st
    I would get a pole mount connection.
    2nd if that is not an option. Pair of dykes
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Crimping Large Wires
    Banned - Busted For Scamming
    Feb 2009
    4 gauge is gettin up there, still might be able to do it with a pair of crimpers, the good ones you buy at home depot, they are klein, for electricians (used to be one lol) or i used to use a hydraulic crimper, but i know you wont have access to one it was a $3000 tool
  4. #4 Re: Crimping Large Wires
    GTP Level Member dstout's Avatar
    ky
    if you know any electricians they might have access to a larger crimper for something you need crimped or before you install the wiring take the cable and connectors to a shop and they would prob. do it for nothing.
    idk....call around to some different electrical shops and see what they say.
    You don't want to buy the tool for a couple of crimps unless you are going to do a sh*tload of crimps.
    We crimp ground lugs on #6 ground wire all the time and you would need a crimp tool at least that big and that crimper is the same size as large bolt cutters.
  5. #5 Re: Crimping Large Wires
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    I always crimp my connections and then solder them as well. If you don't have a big enough crimping tool
    You can take a metal punch and hammer the punch into the metal connector (once wire is inserted into connector) which will put a dimple in the metal which will preven the wire from sliding out. Then you can use a blow torch (mini or big one) and heat the connection up and then insert solder into the connector. The solder will want to flow to the end of the wire because of the capillary action going on.
    When we built my dads plane, we rented a electrical crimper that could crimp huge wires. Then every crimped connection was soldered which will cut down on resistance as well as offer a security net from the connection from ever breaking loose.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  6. #6 Re: Crimping Large Wires
    ky
    Quote Originally Posted by JJ91284 View Post
    That would work, since we are not dealing with a high voltage here, 14.5-14.8 at the very highest normally.
    In electrical applications soldering connectors is unacceptable......in this application there should be no problem.
    I wouldn't want you to burn your house down due to a electrical fire.
  7. #7 Re: Crimping Large Wires
    Schaumburg, IL
    Quote Originally Posted by dstout View Post
    yeah I knew that, aviation and automobiles use low voltage systems so thats why I recommended it. I know my dad re-wired his sailboat and we did the same thing since the boat is on 24 volts
  8. #8 Re: Crimping Large Wires
    Feb 2009
    soldering is the best connection period in automotive applications
    As far as best connection? Welding lol, thats what i used to do SUBSTATION WORK. The bus was 1/2" aluminum and welded the cross ties, as far as the flexible lead connections, had lugs crimped on both ends, with a 60 ton crimper. Then it was bolted to the bus with four 1/2" bolts
  1. how large can a GP have
    By hacket in forum Tires & Wheels
    Last Post: 03-19-2009, 12:34 PM
  2. Large grass fire in tulsa. I was 20' away. PICS!!!
    By Toofastgs in forum Off Topic Discussion
    Last Post: 01-05-2009, 12:11 AM
  3. prj wires and more
    By Golgo13 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2008, 08:23 PM
  4. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
  5. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
