are the prj wires known to cause alternator whine? If not I have a couple other questions.
I also have a constant high pitched whine coming from my tweeters. without the car running, just anytime the hu is on. Originally thought it was the polk momos that were in the car, turns out not but they were shot anyway. Replaced with infinity perfects.
Discovered when the mtx 4 channel was switched to low pass the noise disappeared. So I was now sure it was coming through the tweeters. Replaced rcas and relocated chassis ground, no luck.
Going to try to use a old eclipse amp i have laying around, if still no luck I'll rewire the speakers with new wire and see what happens.
I am using an old pioneer premier hu, but I have had no problems with it before. I have heard pioneer decks like to have and extra ground attached to the rcas or the radio chassis but I'm not sure if thats the case.
Am i missing something?
