Thread: New System help
Results 1 to 9 of 9
  1. #1 New System help
    SE Level Member 0LmtdGP3800's Avatar
    Feb 2009
    Iowa Falls, Iowa
    Alright. Finally broke down and decided to put a system in my GP. I've had plenty of systems in my GPs and they all have been too loud.(kicker CVRs, kicker L5s, JLs, MTX Thunder 8000s.) Ive been just wanting something to put a little more beat behind the music. So I bought a 10 inch Kicker L7 Solo baric, and bought a ported box. I just got it installed today. I have a JVC head unit, 8 gauge Stinger power wire, 8 Gauge Stinger ground wire, and Stinger RCAs, MTX 421D Amp, 10 inch Kicker L7 Solo Baric in a ported box.
    My question is, am I under powering it?
    Do I need a bigger amp? If so explain what I need please.
    Thanks in advance.
  2. #2 Re: New System help
    St. Louis Mo.
    I personally would go with 4ga wiring to be on the safe side of things. Looking at the specs of the sub, I would say yes you are underpowering it. Here is what the Kicker site rates your 10" sub, 1200 Watts Peak and 600 RMS. Your amp does, 1 channel(s) , 300 Watt - 2 Ohm - THD 1.0 % - 12.5V DC - 1 channel(s) , 210 Watt - 4 Ohm - 14.4V DC - 1 channel(s) , 420 Watt - 2 Ohm - 14.4V DC - 1 channel. So even at its peak it is still NOT getting the max RMS. Its almost 200RMS below its rated level.
    So in sort, YES you are under powering that sub.
    James Shafer
    St. Louis MO
  3. #3 Re: New System help
    Feb 2009
    Iowa Falls, Iowa
    Damn you did your research! and thats why i love this website, nice guys like yourself! thanks for the input. so what would you prefer for a amp to use? specifications etc.
    also just got done hooking up my cvr's n my car quick just to tinker around, and once i got done playing them at a decent level for about 15 minutes, when i went to un hook the speaker wires from the terminals on the box, the ground terminal was hot. any idea whats going on there?
  4. #4 Re: New System help
    Springfield VA
    depending on the specs of the box you might not want to feed them full power, if the box isnt tuned/built for that sub and you feed them a **** ton of power the sub will start to rip itself apart
    Quote Originally Posted by UR LOSN View Post
    all depends on how fast/broke you want to go.
  5. #5 Re: New System help
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    That 401d is gonna be putting out closer to 450-500watts.
    Those style of amps from mtx are still considered the best amps they made. and like a 03+ cobra are really under rated.
    With the length of the car you will be running 17+ feet
    Yes you need to run a 4awg wire.
    8awg is really for a total max power of 300 watts.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: New System help
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    u need 4g wire...and that L7 can handle its RMS with ease....I dunno about ur amp or what its rated at...you can always add another 10 incher to it with another amp
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  7. #7 Re: New System help
    Willoughby, Ohio
    you can overpower your kicker and be ok... kicker can handle alot as long as there is NO distortion make sure to tune it and tune it again after it breaks...ive ran 2 1000 watt RMS amps to my 750 watt RMS CVX subs at 1 ohm for over a year...no problems
  8. #8 Re: New System help
    Leo,In
    i used to have 3 l7s in a cavalier. my everyday driving with it i would run about 1k to the l7s and at comps i would run 2k to them on a burp. dude l7's love power. as long as you tune correctly they will be alright. they also like a big box. go big and low with the tune and it will be real nice for ya. go with a kicker kx1000 or or jl1000/1 and u will be real happy
  9. #9 Re: New System help
    Willoughby, Ohio
    i agree w the dude above who appears to have the same car as me /\
  1. My system
    By durag14 in forum Audio, Security & Visual Electronics
    Last Post: 03-12-2009, 08:25 AM
  2. ABS System?
    By mcg_999 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2008, 10:40 AM
  3. ABS System
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 06-04-2008, 01:17 AM
  4. new car = new system
    By ninjamonkey in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2008, 05:43 PM
  5. How to put in a Nav system
    By gp04 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2008, 12:33 AM
