Thread: Boost by pass
Results 1 to 5 of 5
  1. #1 Boost by pass
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    I ordered a pcm from overkill and this is what he said (I am putting in a S/C engine in place of my N/A on my 2005 gp) any input or advise.
    This is what he said:
    Only question mark on doing the swap is hooking up the boost bypass valve. I'll look through my wiring diagrams and try and find the PCM PIN for it, then I'll scan it so you know where it is. If it hooks up like the pre-gen (more than likely), you'll need to hook up the two wire connector to the PCM PIN and the other to a 12 volt source.
    TIA
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: Boost by pass
    just dont hook it up at all. mine is run with one vacuum line, thats it. you need to leave the lower nipple open to the atmosphere.
  3. #3 Re: Boost by pass
    Apr 2008
    ny
    Thanks for the info i didn't know that.
  4. #4 Re: Boost by pass
    May 2008
    staten island,NY
    mine is the same way as bio suggested....looks like you have no need for that hv3 huh?
  5. #5 Re: Boost by pass
    Apr 2008
    ny
    Quote Originally Posted by QwikGT View Post
    posted it for sale last night and sold last night but it looked nice sitting in my garage for a little while...
  1. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  2. yippie pass the emission test
    By nemesis in forum Off Topic Discussion
    Last Post: 07-04-2008, 03:44 AM
  3. Great deal. should not pass up if your looking for subs
    By bula81069 in forum Audio, Security & Visual Electronics
    Last Post: 04-09-2008, 03:55 AM
  4. Vids of my 13.1 and 13.2 pass
    By fst in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:38 AM
