Thread: Noise with 4 channel amp.
Results 1 to 20 of 28
Threaded View
  1. #19 Re: Noise with 4 channel amp.
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I have a Pioneer HU too and I can not get that damn noise to go away I will try this To fix it. I have tried grounding just about everything and no luck but I did not try this I will try and get back to everyone.
    You can pulg your RCAs in with the wire there on top of the wire or do you do this on the outside of the RCA Plugs
    Mine is A P5000
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. channel plate input shaft sleeve scored.. HELP!
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 10:43 PM
  2. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
