Thread: Noise with 4 channel amp.
Results 1 to 20 of 28
  1. #1 Re: Noise with 4 channel amp.
    GTP Level Member dstout's Avatar
    ky
    That would be a good idea since he has the same HU as you do, if he has no noise then maybe yours needs to go into the shop for repair.
  2. #2 Re: Noise with 4 channel amp.
    St. Louis Mo.
    If you are still getting that noise out of HU, more than likely the piezo* fuse inside the HU blew. I am misspelling the name of the fuse, but it is something that can be only replaced by a professional or sent back to company to be repaired.
    I have a Pioneer 6000 HU and it had some serious ground noise issue and I fixed it by doing this........
    I believe you mentioned that you tried this, but with no success? I am not sure if you set yours up like mine, but if you didnt? You might want to try and do it like I did to mine. It worked WONDERS!
    If that doesn't solve it, I would say take it back or get another HU unfortuately
    James Shafer
    St. Louis MO
  3. #3 Re: Noise with 4 channel amp.
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Quote Originally Posted by GeddyLee View Post
    WOW FREAKIN AMAZING this worked AMAZING I can't beleave it everying works perfect now and it sounds better than it ever did before I tried to fix this on and off for the past 8 months
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. channel plate input shaft sleeve scored.. HELP!
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 10:43 PM
  2. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
