Thread: Noise with 4 channel amp.
Results 1 to 20 of 28
  1. #1 Re: Noise with 4 channel amp.
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Right now I have about a foot and a half of wire from the amp to a ring terminal on one of the strut tower bolts. I did sand the paint off around the stud but Iwill try moving it to a better place. How would I attach this ground lug you speak of? I am not sure what it would look like.
    Thanks.
  2. #2 Re: Noise with 4 channel amp.
    GTP Level Member dstout's Avatar
    ky
    Something similar to this, it can be screwed to the sheet metal just get clean metal where you decide to mount it. By that I mean you want metal that is free from paint or rust under the ground lug.
  1. channel plate input shaft sleeve scored.. HELP!
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 10:43 PM
  2. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
