If they are any type of decent amps. If you havent got the amp yet then get a nice amp that will do 1ohm. Another way to power poth subs. Its a 50/50 the amp will work is run it at a 1.6ohm load ( should if a quality built amp)
Wire the first sub in parallel then series wire the other sub.
