Quote Originally Posted by JCG's-GTP View Post
If they are Dual 2s i would go with the mono. series to parallel would bring you at 2ohm and the mono amp would be more efficient 2ohms then the 2 channel. Most 2 channels are made to run 4ohm bridge and the farther you drop them in ohm the more heat,distortion ect... you get. And no matter what the subs are wired to as long as they are wired to where both have the same final impediance per sub they will always "split" the power
Thank you...seriously everyone kept saying well use the mono because it wont split the power . Thanks for the advice, but for some reason I always remember hearing the more resistance you had the less distortion you get. AS for heat, I know resistors get hot, but I didn't know it would make a difference between 2 and 4 ohms.
