Thread: mono amp vs two channel
Results 21 to 40 of 43
  1. #21 Re: mono amp vs two channel
    Nov 2008
    Chicago
    Glad I could help.
    And yes, THD vs Speaker load vs Power Supply is a whole nother convo
  2. #22 Re: mono amp vs two channel
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    comongoose if u already know so much about audio, lol why did u need to ask the question?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #23 Re: mono amp vs two channel
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    well i didn't think about the coils having a max rms load of 250 to each, so i knew something here was missing. i need to know why things need to be done so i can make the adjustments in the future. The whole coil thing seems obvious but i kind of overlooked it. I guess I always figured t was just for impedance configuration solely. Plus I'm on a tight budget and want to buy the right amplifier.
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  4. #24 Re: mono amp vs two channel
    Aug 2008
    Fayetteville, NC
    Ooo Ok...cause u seemed to know alot more about audio then intended in the first post
  5. #25 Re: mono amp vs two channel
    Nov 2008
    Chicago
    I overlooked the same thing on my first system
  6. #26 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    Quote Originally Posted by offroadfury6 View Post
    lol...thanks, there are always bigger fish though.
    -1996 Acura TL
  7. #27 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    now i think of it, i have ran these type rs at one time or another on one coil. I'm going to have to check their impedance make sure i didnt screw anything up. lol
    -1996 Acura TL
  8. #28 Re: mono amp vs two channel
    Aug 2008
    Fayetteville, NC
    yeah might wanna do that depending on the power u put to it ... if u paid for the power, please use it
  9. #29 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    yup, just checked them and they are putting out perfect resistance. thank god, those things r expensive. The only reason i got them was because my father gets alpine wholesale rates. thats the only real car audio company deals with.
    -1996 Acura TL
  10. #30 Re: mono amp vs two channel
    Aug 2008
    Fayetteville, NC
    too bad its not Kicker
  11. #31 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    everyone loves kicker. My roommate has 12" L7 powered by a nice ass RF amp. To me it sounds horrible, and very distorted. ONce again could be installation. I'm not a huge fan of shaped subs. I feel like a omni sound should come from a round object. SOny xplodes demonstrate how much funny shaped subs=fail.
    -1996 Acura TL
  12. #32 Re: mono amp vs two channel
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Kicker squares can be loud when done right but i have ALWAYS had mechanical noise from them. They split around the corners at times too and gotta love the smell they put off when the coils get warm. Only exception is the SoloX. Those are just plain nasty but I still rather have my w7s
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  13. #33 Re: mono amp vs two channel
    Nov 2008
    Chicago
    sony is just straight up fails when it comes to car audio IMO. JL totally rocks.
  14. #34 Re: mono amp vs two channel
    Feb 2008
    Nashville
    Quote Originally Posted by FuglyGTP View Post
    Fugly, I think me and you will get along just fine.
  15. #35 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    I agree, sony is in walmart for a reason. I remember when I was younger it took me forever to persuade everyone how bad sony was. Everyone got suckered into their cheesy marketing hype SONY XPLODEs they are EXTREME!!!!!! more like they are extreme crap.
    -1996 Acura TL
  16. #36 Re: mono amp vs two channel
    SE Level Member blackbonnie's Avatar
    Jan 2009
    grand rapids, MI
    im not gonna read the whole thread and i know you dont wanna talk about impedence and that you know how to wire speakers, but that is a big part of your decision. either way, can you post a link to the amps, theres more info needed if you want a real techical answer.
    but in short and from the info i know, just run with the mono amp. there is no real big reason either way on why or why not to run with the mono amp with the info you gave us, but overall with a mono there is less complexity with them. no channels or different transistors, diodes, resistors, capacitors, etc... to run through. more basic design, less components to drop signal across, and more basic wiring configuration inside.
  17. #37 Re: mono amp vs two channel
    Jan 2009
    grand rapids, MI
    i would run on the JL boner, if they were priced to there ability. no reason to have a 72% markup on all products just for your name.
  18. #38 Re: mono amp vs two channel
    Jan 2009
    grand rapids, MI
    Quote Originally Posted by comongoose View Post
    speakers dont have resistance, they have impedence :fyi:
  19. #39 Re: mono amp vs two channel
    Jan 2009
    Gainesville, Fl
    thanks bonnie, ya i got it all sorted out already.
    -1996 Acura TL
  20. #40 Re: mono amp vs two channel
    Aug 2008
    Fayetteville, NC
    speaking of solo-x's i'mma run 2 12" solo-x's with a 2500 watt kicker amp when i get back from Iraq, I think they are 1500watt RMS...not sure, have to double check on that and the size of amp sometime when I feel like ordering them...we're going home from NTC here i think april 6-13th, then fly out of ft. bragg on the 27th i believe to kuwait... plus my daughter is due april 9th sooo I have alot going on to worry about some kickers ;P
  1. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
