Thread: help with monsoon system
Results 1 to 6 of 6
  1. #1 Re: help with monsoon system
    Feb 2009
    chicago
    i would like to know way only 1 person has replied with over 50 views. Thanks bsumpter05.
  2. #2 Re: help with monsoon system
    So you understand how to do the fronts and rears correct?
    As for the subs, the subs match the amp nicely. The subs should be single 4 ohm. If you wire them in parallel, which means combine both + and - of the subs and input that into one + and - on the amp, sshould result in a 2 ohm load. Also ways verify with a multimeter!!! The amps pretty big for those subs if i am thinking correct. I think thier only 150 watts rms a piece so keep your gain fairly low. For power there are boots on both the driver and pass side so take your pic. For ground you can go to a strut tower bolt or a self-tapper and a star washer. Make sure you scrape the paint away to get a good ground
    Lmk if you have any more question, thanks
    brandon
  1. monsoon add on?
    By Morris 04 GTP in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2010, 12:04 PM
  2. Need help with Monsoon sound system please
    By Keith04gp in forum General Tech Discussion
    Last Post: 09-29-2008, 04:51 PM
  3. Monsoon codes
    By 04 GTP COMP G in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2008, 10:55 AM
  4. Monsoon?
    By Berger in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2008, 11:29 AM
