So you understand how to do the fronts and rears correct?
As for the subs, the subs match the amp nicely. The subs should be single 4 ohm. If you wire them in parallel, which means combine both + and - of the subs and input that into one + and - on the amp, sshould result in a 2 ohm load. Also ways verify with a multimeter!!! The amps pretty big for those subs if i am thinking correct. I think thier only 150 watts rms a piece so keep your gain fairly low. For power there are boots on both the driver and pass side so take your pic. For ground you can go to a strut tower bolt or a self-tapper and a star washer. Make sure you scrape the paint away to get a good ground
Lmk if you have any more question, thanks
brandon
