Thread: Replacing 2006 Grand Prix with Monsoon system rear speakers.
Results 1 to 8 of 8
  1. #1 Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Aug 2017
    Winnipeg
    Hi,
    looking to replace the rear speakers since they are blown. I have read up on this and realize that Pontiac sends 4 wires to the rear, two for bass, two for tweeters. Trying to find a cheap way of fixing this. I was thinking of putting two cheap speakers for bass in the back with the bass wiring and cutting a hole beside and putting in two tweeters. Would I have enough wire for this or would i have to make it longer? I'll link the bass woofers and tweeters. I'm canadian so the infinity system is quite pricey that is the complete system.
    https://www.crutchfield.ca/p_777P52B....html?tp=73199 - woofer
    https://www.crutchfield.ca/p_777P35B....html?tp=73199 - tweeter
    I realize that this is a pretty junk system but the car is getting long in the tooth and dont have much money at the moment.
    thanks
  2. #2 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    you need to find the same ohm speakers and install them, nothing else will sound right. no the right ones are not cheap. even used can be a bit pricey.
    or you buy a new HU, and run all new speaker wires and then you can run normal speakers.
  3. #3 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Aug 2017
    Winnipeg
    So if I install a new head unit should I put in another amp, or is it not needed in most cases?
    Sent from my ONEPLUS A3000 using Tapatalk
  4. #4 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    monsoon crap is monsoon crap, it only works on monsoon crap lol so you could gut and sell off the amp and bass speakers back there.
    new hu and new amp all new speakers and wires to them cause the monsoon stuff is super thin and dont work well for normal speakers.
    easiest route here clearly is buying the right new speakers.
    i almost forgot, if your speakers are rotted out around the cone to frame, they sell a kit to fix that. seen a few guys go that route as well.
  5. #5 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Aug 2016
    CT/RI Border
    https://www.crutchfield.ca/p_108R962...EF-9620cx.html
    Is what you should buy. Don't cut holes, they sell adapters to keep the tweeter on top.
    Sent from my ASUS_Z00TD using Tapatalk
  6. #6 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Aug 2017
    Winnipeg
    If I were to just buy a new amp, most say 4 or 5 channel Max. How do I still use all 7 speakers. Will I be able to?
  7. #7 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Aug 2016
    CT/RI Border
    You have "7" speakers, not 7 channels. The monsoon system counts in an odd way. Left rear, right rear, left front woofer, left front tweeter, right front woofer, right front tweeter, dash center channel.
    In an after market system this would typically be considered a 5 channel system, but due to how the monsoon is wired they count it as 7.
    Now, if you are going to replace the entire system, be warned, you will be best served replacing the wiring all around as the wiring for the monsoon system is very thin/cheap and won't handle a real system very well.
    Many people when replacing the whole system remove the center channel. I actually enjoy the center speaker but to each his own.
  8. #8 Re: Replacing 2006 Grand Prix with Monsoon system rear speakers.
    Jun 2015
    Canada
    I've got infinity kappa 6x9 that are wired to work with monsoon if you're interested.
    Uses the same factory connector.
    Shoot me a PM if you're interested
  1. 2006 GXP - Removing Rear Speakers Completely (Monsoon System)
    By GXPerforms in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2015, 05:29 PM
  2. speakers for 04 Grand prix with monsoon
    By ndbn in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2014, 03:20 PM
  3. Replacing rear speakers w/monsoon and airbags
    By bjm306 in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2013, 07:53 PM
  4. 2006 Monsoon system- dead 6x9s
    By MSUvball14 in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2012, 11:20 PM
  5. Replacing Monsoon System Completely Help With Head Unit
    By Ryan71695 in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2012, 06:01 PM
