Thread: Opinions on Infinity Kappas for doors and rear deck?
Results 1 to 3 of 3
  1. #1 Opinions on Infinity Kappas for doors and rear deck?
    St. Louis
    Since I have the entire interior stripped right now (down to the sheet metal), I figured I'd go ahead and upgrade the speakers a bit. Looking at the Infinity Kappa 62.11i 6 1/2" door speakers ( I know I need to mod the mounts to fit them), and Infinity Kappa 693.11i 6x9's for the rear. Anyone have experience with these speakers? I know there are some audiophile guys here that may have some good input.
    I'm not looking to win any SPL contests, just trying to upgrade a bit. I'm not going to connect the factory tweeters in the sail panel up front, and have a line on a Pioneer DEH-X8800BHS from a friend. I don't want a sub right now, but I will be running all the cables to the back in prep of one and an amp in the future. Also will be installing new speaker wire for the doors/deck since I have access to everything. Of course I'll be ordering the adapter harness to retain the chime and steering wheel controls. And no, I do NOT have the Bose system in my 00 GT.
    Also, not going double-din, and not getting a flip up display unit (will block the vents and look dumb).
  2. #2 Re: Opinions on Infinity Kappas for doors and rear deck?
    Aug 2016
    CT/RI Border
    I believe the chimes and tones were not added to the radio until '05+ but I could be mistaken.
    Do you have a budget to spend? I'd advise getting component speakers and replacing your sail panel tweeters.
    Infinity is a great brand and most monsoon guys get the 2(3) ohm components as they are the best when retaining OEM wiring/amp.
    Honestly in my '99GT coupe I didn't need subs, the 6x9 alpine S drove enough low end with an aftermarket head unit.
    Sent from my ASUS_Z00TD using Tapatalk
  3. #3 Re: Opinions on Infinity Kappas for doors and rear deck?
    St. Louis
    You're correct on the chimes/tones. So used to finding posts on the 04+ cars.
    I'd love to get components, but getting them mounted correctly (i.e.- not in the factory tweeter location) is more than I want to mess with right now. I know they would sound better in the long run but I needed to pick something with relatively easy install and go with it.
    So glad I don't have the Monsoon/Bose nonsense.
    Just found out I lost out on the Pioneer, so I picked up an Alpine CDE-163BT. Going to go with the Infinity's for now. For the stereo, all install pieces needed (including steering wheel adapter), and all 4 speakers I spent $450 so I can't complain. Of course this doesn't account for new speaker wire and amp install kit.
  1. 5.25s in rear deck
    By XxMbXx in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2013, 09:03 PM
  2. rear deck
    By ssiebor14 in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2013, 11:26 PM
  3. rear deck
    By jhintz in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2013, 02:36 PM
  4. ported rear deck
    By abuckley1290 in forum Audio, Security & Visual Electronics
    Last Post: 12-09-2009, 03:05 AM
