Thread: Stupid question about Aeroforce installation
Results 1 to 10 of 10
  1. #1 Stupid question about Aeroforce installation
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    I'm about to order an Aeroforce gauge for my 04 Comp G, but I'm looking into how to hook it up and I'm getting conflicting information. Some say it's plug-and-play to the OBDII port, others say you need to wire power to it. What does it take to install one of these in my car? I don't want to wire in a wideband setup or anything, just monitor KR. I know this has probably been answered dozens of times before, but I've found 3 different answers.
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: Stupid question about Aeroforce installation
    id download in the owners manual and follow it. it cant be that hard. if you dont understand the directions, keep reading till you do.
  3. #3 Re: Stupid question about Aeroforce installation
    Kemmerer, Wyoming
    A lot of cars are different. My 99 and 2001 both wanted a power wire to cycle on and off normally. Before I used the add a circuit to give them power, the gauge wouldn't turn on when the car was started unless I unplugged it and plugged it into the obd2 port.
  4. #4 Re: Stupid question about Aeroforce installation
    Apr 2015
    Illinois
    Here's hoping it works like it should, from what I understand all 04+ should be plug and play. Got everything to make it look stock, too
  5. #5 Re: Stupid question about Aeroforce installation
    Should be pnp I think the later years had to run a wire for the 12v
    04 Comp G.
  6. #6 Re: Stupid question about Aeroforce installation
    Apr 2015
    Illinois
    Can't tell if you forgot an i in wire or an h in whore lol
  7. #7 Re: Stupid question about Aeroforce installation
    Jul 2010
    Coquitlam,BC,Canada
    Plug in the OBD. If it works, great. If not, you need the power wire.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Stupid question about Aeroforce installation
    SE Level Member MM06GT's Avatar
    Jan 2013
    SF Bay Area
    I'm not sure about the 04-05s, but for my 06 it's plug and play.
    Silver 06 GrandPrix GT: K&N cai//3" catless DP//SS plog//Rear ported Mani//AL xp 104s//180* TS//ZZP 10.5 wires//TB HS//ZZP 3.2" MPS//E85//50lb injectors//1.9 YT rr//90lb sprs//Impala DP brakes//AF scan gauge//Mini AFR//BLK 18x9 saleen replicas//Overkilled.
  9. #9 Re: Stupid question about Aeroforce installation
    Apr 2015
    Illinois
    Got it, just plug and play. Now I've just gotta set it so they don't both read KR lol.
  10. #10 Re: Stupid question about Aeroforce installation
    Have it cycle through 8 different things, best way to use that gauge.
    Then you can just click either button to bring it out of cycle mode and be able to pick two pids and watch them whenever you need too. Watching just kr or just timing all the time doesn't put the gauge to use really.
  1. AeroForce Interceptor installation help!!!!
    By Hot wheels in forum General Grand Prix Discussion
    Last Post: 03-17-2015, 10:07 AM
  2. Aeroforce Scan Gauge Installation?
    By 2007GPGTSC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2013, 02:41 PM
  3. One Question about Audio Installation
    By deonte3455 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2013, 12:30 AM
  4. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  5. Please help! Question about 6x9 installation!
    By Deebo in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2010, 09:21 PM
