Thread: How to remove/move battery to trunk GXP/GTP/GT
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 How to remove/move battery to trunk GXP/GTP/GT
    I live here. DirtDog's Avatar
    Jun 2012
    How to replace and/or move battery to trunk in a Grand Prix GXP
    So for starters…follow these steps in the below link to remove the batter and replace it if that all you want to do. If you want to move the battery to the trunk as I did continue reading and looking at the pictures for the how to.
    http://www.gpona.com/forums/gxp-area...cs-t26509.html
    Now for moving the battery to the trunk (means you will never have to do all that again to replace the battery or anything)
    Your shopping car needs to include the following
    20feet of zero or 2 gauge wire
    Ring terminal connectors for whatever gauge wire you got. I think 4 will be enough.
    Ring terminals for 4 gauge wire. 2 but I would have a 3rd just to have a spare
    1.5 feet of ground wire
    Battery – I got an optima red top Group size 34/78 battery
    Specs – 800 cold cranking amps; 1000 cranking amps; 41 pounds; and a 100min reserve capacity
    Battery terminals
    Sand Paper
    Power Distribution Post (I made one which I will show on down so you can see. Mainly I didn’t want to wait till after Christmas so I just made one)
    Solder if you want. But you could use a hammer instead. I soldered and hammered mine.
    http://www.iem-services.co.uk/asps/u.../big/977-1.jpg
    So for starters…….I thought in order to remove the fuse box you had to take all the fuses out…..and I did. But luckily I had this to go off of because I was smart enough to take a picture first
    Picture of everything taken apart
    Now for your distribution block…if you so choose to make your own as I did.
    I used two pieces of wood and jb welded them together
    Then drilled a hold and alse made ¼ of the hole large enough for the head of the bolt to go back into the wood so it doesn’t touch any part of the inside of the car. (Would be bad if it did)
    To fill the hole in its filled with mostly jb weld then a layer of caulking I had laying around just as a precaution.
    The mess I made during the construction of this creative piece of work. O and I painted mine black.
    That is the block mounted under the hood. I did drill another hole for it to mount there with and also drilled a hold in the metal of the car. I haven’t filled that hole in yet…but have every intention to soon.
    Now the stock ground under the hood will need to be grounded somewhere…here was my original location…but I ended up having to put it else where
    Just some pics
    In the below picture you can see the grounding point that I ended up using
    Here you can see how the distribution block I made works….its kinda like the awesomeness of the car
    And close up of grounds
    For running all the wires through the car…..i used this hole and the grommet. Just cut the grommet a little bigger and you can fit things through it
    This is how 91ParkAve did his. Just so you can see other ways
    And his ground point
    And another of his
    Update with more pics and a few more tid bits of information.
    so the above pic is where I currently have my ground but with my car the sheet metal isn't a good enough ground for the starter to crank the motor over well so i am having to run another 0 gauge wire to the engine block to carry the current....doing that tomorrow.
    this battery is an absolute beast....had it tested and it has 994CCA and is only rated for 800. if only my grounds were good enough. and that 13+ volts is with the car off lol
    i placed my battery on the passenger side of the car as close to the rear seats as possible. i do have a battery box to put it in though just to protect it.
    And i need more torches
  2. #2 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    More pictures tomorrow after i clean up some. Also would be nice if a mod could stickey this in the 5.3 section pretty please
  3. #3 Re: How to remove/move battery to trunk GXP/GTP/GT
    Arizona
    Don't forget to throw some clear rtv silicone over the ground so it dose t rust and corrode and great job on the swap!!
  4. #4 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Good idea. So I tested all my voltage at every possible place. And the resistance of my ground wire. And their all good. But I still have that starting issue. I'm thinking my ground wire may be to long. Its exactly 3 ft. I can shorten it at least a foot easily. Right now it has a resistance if 00.000 though
  5. #5 Re: How to remove/move battery to trunk GXP/GTP/GT
    what is the starting issue exactly?
    3 foot ground wire should not hurt anything.
  6. #6 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    It doesn't wanna crank very well. Like the first turn over it struggles really hard and I can't figure out why.
  7. #7 Re: How to remove/move battery to trunk GXP/GTP/GT
    are you using a new battery? or a older one?
    seems like something has a weak connection if the battery is in good shape.
  8. #8 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Battery is brand new. With car turned off it sits around 13.1 volts. I had it tested last night and is putting out 994 CCAs and is only rated for 800. I dunno what else to check cause everything looks good
  9. #9 Re: How to remove/move battery to trunk GXP/GTP/GT
    did you run a new power wire to the starter with all the new stuff?
    if not maybe that wire is bad and the currents not flowing good from far away.
    if you see copper at the ends of the wires near the end loops, that wire is suspect.
  10. #10 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Hmmmm...I shall investigate further and report back my findings
  11. #11 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    sheetmetal bodies are horrible high current ground paths...
    run a seperate 2ga ground cable from batt to block under the car (no chance of short on ground)
    then youll have a nice snappy crank
    sheetmetal grounds suck
    ~James~ Psychotic Gearhead
  12. #12 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Which block under car?
  13. #13 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    the engine block/bellhousing studbolt
  14. #14 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    The battery is in trunk. Are u referring to the ground wires under the hood? There's a few grounds there
  15. #15 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    primary high current draw is the starter, your just making sure it has the least amount of voltage drop at full current load
    once the bat neg post is connected directly to the block/bellhousing ground bolt... you wont have any more issues but id also suggest a ground bridge to the unibody/sheetmetal grounds
  16. #16 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    I can't connect battery negative post to block...its all the way in trunk. That'd be a 16 foot ground wire!
  17. #17 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    exactly
  18. #18 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Longer the ground wire...the more resistance. Everyone I know says the shortest ground possible is best
  19. #19 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    ...but when that 150-250 amp surge is trying to turn your engine over...that "short ground wire" becomes a:
    battery neg terminal>ring terminal>wire>ring terminal> sheetmetal>series of spotwelds>sheetmetal>series of spotwelds>sheetmetal>spotwelds>sheetmetal> spotwelds>sheetmetal (now we are at the pass front unibody rail)> ring terminal>wire>terminal>groundbolt>starter motor negative windings
    or it can flow:
    batt>ring terminal>high grade fine strand copper wire>ring terminal>ground bolt
    try to guess which is the one thats gonna flow a large amount of current with the least amount of voltage drop
  20. #20 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    use a set of jumper cables and run a quick test ground from the bat neg to a bracket on the motor...id bet it cranks over much better
  1. Safest way to remove battery?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 01-21-2013, 08:41 PM
  2. Remove battery
    By swhdmax in forum 5.3L V8 (LS4)
    Last Post: 02-08-2012, 01:30 AM
  3. easiest way to move battery to trunk?
    By z3r0 in forum General Tech Discussion
    Last Post: 08-12-2011, 11:37 PM
  4. how can I remove a battery
    By cjmonahan in forum 5.3L V8 (LS4)
    Last Post: 09-10-2009, 08:22 PM
  5. Remove the factory bose amp in the trunk of my 02 GTP?
    By GTPjcoop in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2009, 09:30 PM
