Thread: Remove battery
Results 1 to 4 of 4
  1. #1 Remove battery
    Iowa
    Trying to remove battery on 2007 Grand Prix GXP (5.3V8). Removed the strut cross brace, battery wires, battery tie down strap, and loosened the fuse box. Can't seem to get enough movement in the fuse box to allow the battery to clear. Even had the battery turned on end. I'm concerned about pulling too hard on all those wires. Is there anyway to disassemble the fuse box or at least disconnect one of the wiring harnesses to get the fuse box to move farther out of the way?
  2. #2 Re: Remove battery
    GTP Level Member joshv's Avatar
    canada
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  3. #3 Re: Remove battery
    Iowa
    I spend an hour searching this site for "gxp battery replace" and didn't find anything. Thanks for the link Josh! Not very service friendly but not too bad when you know how it comes apart!
  4. #4 Re: Remove battery
    canada
    When ur on the site scroll down to the gxp section click On ( gxp section ) should be 3rd thread on right
  1. new battery? maybe?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 11:48 PM
  2. Where should I get my battery
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-25-2011, 01:05 PM
  3. battery
    By kjohnson in forum General Tech Discussion
    Last Post: 09-08-2010, 11:05 PM
  4. how can I remove a battery
    By cjmonahan in forum 5.3L V8 (LS4)
    Last Post: 09-10-2009, 08:22 PM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
