Thread: How to remove/move battery to trunk GXP/GTP/GT
Results 21 to 40 of 42
  1. #21 Re: How to remove/move battery to trunk GXP/GTP/GT
    I live here. DirtDog's Avatar
    Jun 2012
    Good idea. I'll give that a try just to see. Thanks for the input. I'll post up results
  2. #22 Re: How to remove/move battery to trunk GXP/GTP/GT
    Nov 2012
    Madison
    Quote Originally Posted by Turbocharged400sbc View Post
    ...but when that 150-250 amp surge is trying to turn your engine over...that "short ground wire" becomes a:
    battery neg terminal>ring terminal>wire>ring terminal> sheetmetal>series of spotwelds>sheetmetal>series of spotwelds>sheetmetal>spotwelds>sheetmetal> spotwelds>sheetmetal (now we are at the pass front unibody rail)> ring terminal>wire>terminal>groundbolt>starter motor negative windings
    or it can flow:
    batt>ring terminal>high grade fine strand copper wire>ring terminal>ground bolt
    try to guess which is the one thats gonna flow a large amount of current with the least amount of voltage drop
    Good write up/how to Andrew.
    Turbo has some meat and potato, real world reasoning there.
  3. #23 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Yup...I'm gonna give it a try with jumper cables and see what's up!
  4. #24 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    So turbo...I now agree with u. My cables weren't long enough to reach from trunk to block so I pulled battery out... and sat it beside car and hooked positive wire right where the one from the trunk was hooking up at and ground to a point right above starter....and bam....fired right up even with headlights on.
    So my thinking is I'm gonna get 20ish feet of 4 gauge ground wire and run under car (protected that is) to battery and also leave my other ground I have back there on. Since power likes path of least resistance
  5. #25 Re: How to remove/move battery to trunk GXP/GTP/GT
    i did not know you were using the body as ground point to connect a solid ground. trying to use the body for a ground sucks most of the time. especially for a hi draw motor like a starter.
    its long ground wire time for sure, as your test just proved.
    that stuff is cheaper if you buy it with no ends, and then solder your own eye loops on the ends. you may have to order it on line but thats the game right.
  6. #26 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    added some more pics to the original post. also since then i have put a clear silicone coating over all bare metals to prevent rusting and done a little wire management under the hood. will do more when i top swap next week.
  7. #27 Re: How to remove/move battery to trunk GXP/GTP/GT
    when you top swap? i thought you had a v8? or you upgrading the intake?
  8. #28 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    get rid of the lead terminal on the positive
    ~James~ Psychotic Gearhead
  9. #29 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Yup I got an ls1. 91parkave's old set up except I'm repainting everything
    I just got me a new MAF and intake and my own throttle body.
    I'm guessing u mean the LED thing reading voltage? It was only temporary. I was going to use it but went with side mounted wiring instead of top.
    Any more things I could do to improve it turbo? Ur advice on running ground straight to battery was spot on
  10. #30 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    btw for best terminal strength i suggest a good quality 3/8ths bolt at least 1" uhl and a flange nut (ace is the place lol) the bolt you thread in by hand to make sure you have 100% thread engagement then tighten the nut...you end up with an easy 9/16ths wrench removal and a full nut and stud reliability
    stock bolts suck and people get too tq happy even with that tiny hex.
    if you go 1.25" uhl you can tighten a std nut under the bolt head and you get a terrific jump start post that makes the oem bolt look like your putting the cables on yer gf's nipple lol
  11. #31 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    thats fine as you have it, the power cable should also get a large copper lug crimped on to get rid of that lead terminal asap
  12. #32 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Hey turbo. I'm at ace now. They have 3/8 1.25 inch but their black and not silver. Doesn't look like itd conduct electricity well
  13. #33 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    And what do u mean by uhl
  14. #34 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Well this is what I ended up with
    and I already have new 3/8 ring terminals for the wires
  15. #35 Re: How to remove/move battery to trunk GXP/GTP/GT
    Arizona
    Didn't your order the post I used in my setup?
  16. #36 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    Which posts?
  17. #37 Re: How to remove/move battery to trunk GXP/GTP/GT
    Arizona
    Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=370935100406
  18. #38 Re: How to remove/move battery to trunk GXP/GTP/GT
    Jun 2012
    O no I didn't order that. I think what turbo is saying is for the actual battery posts. I sorta but not really get what he's getting at. Pictures would help
  19. #39 Re: How to remove/move battery to trunk GXP/GTP/GT
    Arizona
    Lead equals led he meant get rid of the led terminal you have for the positive and go for a copper lug to go to the artery....iirc ace hardware was the only ones who sell 0 gauge copper lugs
  20. #40 Re: How to remove/move battery to trunk GXP/GTP/GT
    hangover park IL
    yeah, that gray bolt on "repair" terminal is made of lead and not a good option over a true crimped on copper lug
    while not the exact hardware i usually get the bolts are for the battery terminals they will work fine.
    i aim for non flanged bolts (just hex head clear zinc) and thread a non flanged nut (or two if longer than 1" uhl-under head length) up the threads and tighten em up to the bolt head. this gives you a 1/2-3/4inch tall hex that jumpercables swoon over....then i put a flangnut on that i use to tighten the terminal (you dont need a flange nut, but washers are annoying)
  1. Safest way to remove battery?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 01-21-2013, 08:41 PM
  2. Remove battery
    By swhdmax in forum 5.3L V8 (LS4)
    Last Post: 02-08-2012, 01:30 AM
  3. easiest way to move battery to trunk?
    By z3r0 in forum General Tech Discussion
    Last Post: 08-12-2011, 11:37 PM
  4. how can I remove a battery
    By cjmonahan in forum 5.3L V8 (LS4)
    Last Post: 09-10-2009, 08:22 PM
  5. Remove the factory bose amp in the trunk of my 02 GTP?
    By GTPjcoop in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2009, 09:30 PM
