what mean with the door? my lights dont dim with a door?
thats what i was talking about, mine are on the stock dimmer for the gauges. But hey if you want to have extra in your car thats cool
well i did kinda what your wanting in my gtp, and the fader for the lights is great. was always close. so in my gxp its even better, i like the evenness of the color. And besides it looks so stock until night time
what you get now? and we all love to tear into things. as long as you dont have any extra screws afterwards lulz
Well for one if I have extra screws left after this...I'll be having problems. But my gates belt came in. My new cv shaft for drivers side came in. The new PS pump came in. New ps lines came in. And still waiting on tons of other things
Sent from my DROID RAZR using Tapatalk 2
Yea...its been leaking for awhile and the rack is starting to get hard to turn so I'm just replacing all of it from lines to pump and at the same time doing a cv shaft and seal along with hopefully an oil change and install some gauges to
Uv been talking about what the dic has to display but i keep my dic on the tranny temp and i put a volt meter in just so i dont have to flip between.. And volt is easier to set up then tranny temp lol
Well who knows guys...I may end up going with a volt gauge...their pretty cheap anyways
Ok though if you were to put a volt meter in and watch for voltage....but if you ever go below 12 volts anyway the DIC will display power saving mode or display that Automaticly so a another waste of a gauge IMO
Voltmeter gauges are cheap anyways well compared to other gauges...
i dont think so, before my battery upgrades along with big three, i could pull the voltage down if i had gains set to high on amp. never seen battery saver. dipped into the 10's enough to shut down the amp. I have a digital voltage readout, the dic isnt that accurate. normally off half a volt at least.
Funny you mention that I've never gone below 13 with the car running especially after I relocated my battery and did 0 gauge wiring. My disc reads 15 driving around now and never goes below 13.8 Now. In traffic with my 1000w and 2 12's. But if I sit with the car off and amp on it will drain of course but not past 12 the dic displays power saving mode and shuts off
Here's what I got right I'll snap more complete pic in a little while when I get back from pt
I have the thread on ls1 tech too but I need to update the pics as well
http://i173.photobucket.com/albums/w...ps70bc8330.jpg
http://i173.photobucket.com/albums/w...173350_779.jpg
