Re: LS4 gauge install question
Circut breaker is mounted behind the battery box in the trunk now. the battery is grounded to the trunk area. I bought a battery post and utilized the winshield wiper resoiver screw to install it there. That is where my battery + leads to and the factory wire for the starter is attached to. I then run another wire off the post to the fuse box where my alternator is also wired to. no issues for months now car runs great HID's never flicker and my voltage is running top notch...knock on wood... I took the time to scrape the paint off major ground connections and then put RTV silicone on top so the ground stays rust free. I also ran some 8 gauge to the tranny from the body. heres some pics my ground is pretty much buried under my intake setup for now.
here you can see where the factory negative now goes to.
http://i173.photobucket.com/albums/w...ps21906dac.jpg
another topview pic of how my wires are ran to.
http://i173.photobucket.com/albums/w...pse7600900.jpg
and somewhere in the mess of stuff is the tranny wire i ran
http://i173.photobucket.com/albums/w...ps1f2ed47f.jpg
Also I thought I'd note that the 0 gauge wire was from eBay I ordered 20 feet for 30 bucks shipped battery post was 8 bucks off of eBay as well. The rest of the misc electrical stuff was from ace hardware
awesome info!!! do you have a my ride thread or anything over on ls1tech.
also for the air/fuel gauge glowshift does have a narrowband gauge that will match the oil pressure gauge that should work
Tinted 7 Color Needle Air / Fuel Ratio Gauge
marines542
Nah never got around to that on ls1 tech if you you just look at all the threads i started you should be able to track most of the **** i did. next week some time ill be going full 4' intake with a Z06 maf. BTW i looked already when i posted about the Air/fuel gauge if they had a narrowband so yea it will work perfectly with your gauge setup
Awesome man. I really appreciate all ur help. I'm gonna a jump onto ls1tech and read thru some more of ur threads. And it also sounds like the a/f gauge will be easy to install so I'm not to worried about that.
Sent from my DROID RAZR using Tapatalk 2
yeah man i love me some ls1tech and for us the ls4 section! same username there for you guys?
Na I gots me a different user name. I never really post over there
why not? i just read really and help out with electrical ?
Cause there's already so much info so I just read...learn more that way. And ask questions over here
Air/Fuel Gauge Pigtail
found this while ordering my pcm tray
and im also updating the original post right now with what gauges i settled on and how to install
You ordering a pcm tray but you don't have a intake yet? If you want I'll be selling my one pictured in my profile soon with pcm tray
How much would u want for it? I already got an intake I made but I like the looks of that and the box and all
