Thread: Best Quality Drilled and Slotted Rotors?
Results 1 to 19 of 19
  1. #1 Best Quality Drilled and Slotted Rotors?
    Jan 2016
    Buffalo
    Have to replace brakes and rotors. bought drilled and slotted on my old car online and they went to s**t after a year. What brand is the best for the gxp?
  2. #2 Re: Best Quality Drilled and Slotted Rotors?
    Buy some 2008-2009?? Buick Allure front rotors, they are the same diameter has the GXP fronts without the drilled holes that love to rust. Those buicks came with the 5.3 engine too but no drilled rotors.
    Pad type is up to you, I prefer the napa "adaptive ones" for good overall performance and really long pad life with zero dusting.
  3. #3 Re: Best Quality Drilled and Slotted Rotors?
    i just went with R1 concepts off ebay. eline series rotors with scorched pads. (they sell kits or front and or back, or both) front and back cost under 200 shipped and i swear to god, these are the best damn brakes ive ever owned. better then the brakes on a new car off the dealer lot.
    a lot of us have bought pads for a 100 bucks that failed to live up to the price tag. these will blow your f ing mind if you dont get tossed through the windshield first lol
    best part is, the rotors do not rust, not ever.
  4. #4 Re: Best Quality Drilled and Slotted Rotors?
    R1's for the GXP are nearly $400.
  5. #5 Re: Best Quality Drilled and Slotted Rotors?
    if you get the black ones maybe. i bought stock replacement for the rear and f body up front, f bodys listed for 120, rears were 80 ish, 10% off for buying two kits and it was 200 shipped.
    http://www.ebay.com/itm/Brake-Rotors...item51e063ea82 bam! id buy these
  6. #6 Re: Best Quality Drilled and Slotted Rotors?
    Buffalo
    I've never had a dustless pad
  7. #7 Re: Best Quality Drilled and Slotted Rotors?
    didnt say dust, said RUST. the eline rotors will not rust. on the dust tho, they start out a bit bad as they bed in, but since then they are low dust for sure.
  8. #8 Re: Best Quality Drilled and Slotted Rotors?
    I was looking for the "best" or better than OE so I looked for better than OE quality rotors, those blanks they sell are of the same quality as a premium rotor from the parts store but with zinc coating.
    The slotted non drilled front/rear combo with zinc coating I found was $375 through them, didn't see a ebay listing on them but I'm not digging for them.
    He has his options that's for sure. The buick rotors with painted caps and coating are like 40-50 a rotor online, then add pads. R1's are an option or even powerstops are having a sale on rockauto for the buick fronts, they are just over $100 for fronts only with pads. I ran powerstops on my silverado and they held up good.
    OE drilled rotors for the GXP are 60-70 each from AC delco before shipping on rock auto, I know for sure the parts store rotors cost way more than that. I'd stay away from the drilled rotors though.
  9. #9 Re: Best Quality Drilled and Slotted Rotors?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have the Powerstop drilled and slotted rotors and I am neutral on them. I've had the fronts for a little less than 2 years and they are thumping. The inner rotor surface has worn down to where the slots are barely there and the dust that gets trapped in them have kind of welded a ridge that makes the thumping when braking. However, I am rough on brakes. I bought the impala dual caliper, rotor and pad bundle through Rock auto. The calipers were red powder coated but the coating looks like crap. It's like they coated over rust. They were zinc coated and still have not rusted so that is good. I might look into the eline rotor/pad setup that Scottydogs mentioned.
  10. #10 Re: Best Quality Drilled and Slotted Rotors?
    Buffalo
    Noo read 2nd post
  11. #11 Re: Best Quality Drilled and Slotted Rotors?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Right here.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  12. #12 Re: Best Quality Drilled and Slotted Rotors?
    ahhhh, ive never seen NO dust. thats like a unicorn stuff there lol
    napa does have some damn good brakes, but will cost ya 300 bucks by the time the dust clears.
  13. #13 Re: Best Quality Drilled and Slotted Rotors?
    I got the factory replacements from RockAuto.
    They work just fine.
    Drilled and slotted, too.
  14. #14 Re: Best Quality Drilled and Slotted Rotors?
    Buffalo
    I been using hawk hps or the blue box
  15. #15 Re: Best Quality Drilled and Slotted Rotors?
    Apr 2015
    Houston
    Not to hijack the thread, but why are people against drilled (and slotted?) rotors? I thought they were suppose to help keep the rotors cooler?
  16. #16 Re: Best Quality Drilled and Slotted Rotors?
    Quote Originally Posted by wikisi9 View Post
    cause its not a race car as much as we all want them to be lol they work fine tho.
  17. #17 Re: Best Quality Drilled and Slotted Rotors?
    Enfield, CT
    Hawk Slotted rotors and Hawk HPS pads are phenomenal. ALSO have f-bodies in the front
    Sent from my LG G3
  18. #18 Re: Best Quality Drilled and Slotted Rotors?
    Enfield, CT
    Oops did not see this was the V8 section my bad
    Sent from my LG G3
  19. #19 Re: Best Quality Drilled and Slotted Rotors?
    Quincy, Mass
    Drilled stay cooler, slotted have more surface area and stop better.
    No more GP 04 Impala SS Indy:
  1. Powerstop drilled and slotted rotors, any good?
    By WhiteGT in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2012, 10:23 PM
  2. New drilled and slotted rotors, ceramic pads (ebay)
    By Peacher213 in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2012, 01:18 AM
  3. OEM Brakes or Drilled/Slotted Rotors For Winter?
    By extreme in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2011, 07:48 PM
  4. Used Drilled Slotted Rotors?
    By Confusingboat in forum Tires & Wheels
    Last Post: 09-23-2010, 07:20 PM
  5. Can drilled and slotted rotors be turned?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 01:55 AM
