Thread: Can drilled and slotted rotors be turned?
Results 1 to 10 of 10
  1. #1 Can drilled and slotted rotors be turned?
    SE Level Member corsagtp's Avatar
    Calgary, AB
    My rotors are warped so I was wondering if warped rotors can be turned and can drilled and slotted rotors be turned? If so, around how much would have two done? Also, anyone know of any parts stores that do it (in Canada)?
    97 GTP - POS parked in backyard
    07 Saab 9-3 2.0 turbo 6-speed - Awesome
  2. #2 Re: Can drilled and slotted rotors be turned?
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    lots of parts stores can do it, or have it done, Canadian tire use to do it, I dont know if they still do. But if it is warped there is nothing you can do. and I'm not sure if you can turn down drilled slotted rotors. drilled maby, but it would kinda wreck the slotted parts...
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  3. #3 Re: Can drilled and slotted rotors be turned?
    Feb 2009
    Red Deer AB
    Some Kal-Tire's do it, and if you bring them in off the car, its $25 each. but they cant do drilled rotors (I just called)
  4. #4 Re: Can drilled and slotted rotors be turned?
    Charles City, IA
    Nope, buy better rotors.
    SMGPFC Two Nipple General
  5. #5 Re: Can drilled and slotted rotors be turned?
    Calgary, AB
    turns out it wasn't the rotors, when I took a closer look it was the calipers. Installed new calipers and she stops on a dime, no more shuttering
  6. #6 Re: Can drilled and slotted rotors be turned?
    SE Level Member SilverBackGorilla's Avatar
    C-Bus, OH.
    Actualy, I had a guy who works for hyundai plant here in MI. and he turned my D/S rears for me and they are just fine. No problems at all.
  7. #7 Re: Can drilled and slotted rotors be turned?
    Jul 2008
    sumter,south carolina
    i had my powerslots turned.... they were warped to hell and back... it fixed my issues.. have done it twice actually.
    02 GTP with mods 05 GP for DD
  8. #8 Re: Can drilled and slotted rotors be turned?
    Calgary, AB
    Where did you have them done?
  9. #9 Re: Can drilled and slotted rotors be turned?
    Heres a SERIOUS question frrom a VERY drunk mother ****er... who here has ACTUALLY LEGIT had a rotor warp on them?
    I don't mean, "OH I REPLACED THE ROTORS OR HAD THEM TURNED AND IT WAS ALL GOOD" i mean ****ing had it checked out by a legit shop.
    Most of the time its the glue on your rotors not being evenly distributed because you went past the thermal limit of your pads. either rebed your pads first or get higher temp pads and rebed them.
  10. #10 Re: Can drilled and slotted rotors be turned?
    C-Bus, OH.
    I bought my R1's used and they needed to be cleaned up cause hey looked like shyt so my buddy took a lil off the top.
  1. Slotted rotors noisy?
    By MBruneaux in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2010, 02:37 PM
  2. Where to get over sized slotted rotors?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 11:45 PM
  3. drilled rotors
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2008, 11:25 AM
  4. Drilled/Slotted or both?
    By GP2003GT in forum Brakes/Suspension/Chassis
    Last Post: 04-20-2008, 12:43 PM
