Thread: Gen V swap or just drop pulley?
Results 1 to 15 of 15
  1. #1 Gen V swap or just drop pulley?
    May 2014
    New Mexico
    I found a gen v with LIM for $375 shipped. I have an 02 gtp that's lightly modded, dp, 180, tr6, tune by reptile. Is it worth it for me to gen v swap? Or should I just get the MPS and go to a 3.4" and get a dyno tune?
    Thanks.
  2. #2 Re: Gen V swap or just drop pulley?
    Feb 2013
    37.295091, -121.930053
    the gen V is worth it.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Gen V swap or just drop pulley?
    It all depends.
    3.4" would be simple...doesn't mean the car will run it knock free either.
    Same with the GenV...and you could be on a stock pulley.
    I'd get a way to scan it before anything. I'd do the modular system, toss the pulley on the GenIII...and enjoy it for awhile. You're not anywhere near maxing out the GenIII.
    I'd port the GenIII while it was off too, at least the outlet.
  4. #4 Re: Gen V swap or just drop pulley?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by Runicdionysus View Post
    Thanks.
    Well, it depends, really. If you want to do more S/C supporting mods in the future, then Gen V all the way. Otherwise, it might not be worth the expense to you.
    It becomes a better performance/$ mod if you can get the blower cheaper, I would look around. At my local pick-n-pull yard, you can snag any blower for $60... so Gen V upgrade is no brainer if you get lucky.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: Gen V swap or just drop pulley?
    May 2014
    New Mexico
    Quote Originally Posted by blueguy View Post
    It all depends.
    I have Scangauge II so I can scan for KR. I want the most bang for my buck, I want to hit 13s- lows 14s ASAP. I ran a 15.07 @94mph on my current setup with a lot of spin at launch and I'm 1 mile high in elevation.
  6. #6 Re: Gen V swap or just drop pulley?
    May 2014
    New Mexico
    I'll have to look around. The upull it here doesn't have any GTPs but I haven't checked the other junkyards.
  7. #7 Re: Gen V swap or just drop pulley?
    Knoxville, TN
    You might have to wait awhile for an 04+ supercharged Grand Prix to come in. Unless you need this mod right away, it could very well be worth waiting for.
  8. #8 Re: Gen V swap or just drop pulley?
    GXP Level Member
    Mar 2015
    Tomball
    When you go to buy a supercharger, what do you tell them it is? I used to say it would be under the manifold section and I would usually pick them up for about 75 for the late model stuff. There is an 04' in there right now that I hope is there at the end of the week.
    Jeff
  9. #9 Re: Gen V swap or just drop pulley?
    if your just after a time slip spray it for under 500 and call it a day lol........ as for the gen5 if you plan on keeping the car for a while id pull the trigger on a gen5 swap. or spend that cash on a set of rockers. rocker downpipe 3.4 setups are pretty solid and many people run that combo.
  10. #10 Re: Gen V swap or just drop pulley?
    May 2014
    New Mexico
    Quote Originally Posted by 98BrokeMyCarVet View Post
    That's an idea too. Would that combo put me at 14.1-14.2 range? And are we talking the 1.9 rockers from zzp?
  11. #11 Re: Gen V swap or just drop pulley?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I'd only go with the Gen V if I got it really cheap, or was maxing the Gen III out. Don't forget to factor the $100 TB adapter into the cost.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: Gen V swap or just drop pulley?
    Knoxville, TN
    Quote Originally Posted by 99GT2dr View Post
    Very good point!
  13. #13 Re: Gen V swap or just drop pulley?
    May 2014
    New Mexico
    You're right I totally forgot how expensive those are.
  14. #14 Re: Gen V swap or just drop pulley?
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    I ran 13.8 with basic bolt ons. Car has 207000 miles. Ive had her since she was new. I got out of the W-body game for a lil bit but Im back now!!!
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  15. #15 Re: Gen V swap or just drop pulley?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Where in new Mexico are you?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  1. pulley drop
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 11:41 PM
  2. 3.4 pulley drop
    By hollas13 in forum General Tech Discussion
    Last Post: 07-18-2013, 08:36 AM
  3. pulley drop help!
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 11:32 PM
  4. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  5. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
