Thread: Gen 3 Gen 5 Hybrid
Results 1 to 20 of 29
  1. #1 Gen 3 Gen 5 Hybrid
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Ive done searches on this in the past and came up with nothing. Whats modifications are needed to run gen v rotors in a gen 3 case?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Gen 3 Gen 5 Hybrid
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    i hear that it's get rid of a hood and grab some injectors.
  3. #3 Re: Gen 3 Gen 5 Hybrid
    Apr 2014
    South Haven, MI
  4. #4 Re: Gen 3 Gen 5 Hybrid
    http://www.grandprixforums.net/threa...ht=hybrid+swap
    M112 rotors in a GenV case or bust.
    Don't bother messing with the GenIII.
  5. #5 Re: Gen 3 Gen 5 Hybrid
    What we are trying to say is...There are no gains to be had by even trying to stuff Gen5 rotors in a Gen3...you will have the same output. If you are that committed get the entire Gen5 blower and stick it on.
  6. #6 Re: Gen 3 Gen 5 Hybrid
    Apr 2014
    South Haven, MI
    Quote Originally Posted by JamesIvey24 View Post
    Its my stuff, i bought it with the money i made and i can choose to keep it or sell it. Simple as that. I didnt think people would be so moody over a hood.
  7. #7 Re: Gen 3 Gen 5 Hybrid
    ...or judging by your signature...you will need to do what Blue posted to get what you want.
  8. #8 Re: Gen 3 Gen 5 Hybrid
    Apr 2014
    South Haven, MI
    Fair enough. i just didnt want to buy an adapter plate. Oh well, i guess ill just get the plate.
  9. #9 Re: Gen 3 Gen 5 Hybrid
    Quote Originally Posted by BoostedPontiac View Post
    I don't care about your hood.
    It's your car.
    I don't drive it.
    However, I'm giving you the advice you're asking about.
    Don't waste your time with the swap that's turning the gears in your brain.
    If you're going to swap anything, toss on the GenV, it's easy. I just got an adapter for like $50~.
    Or, do this: https://www.youtube.com/watch?v=Cu2k9uE86oM
  10. #10 Re: Gen 3 Gen 5 Hybrid
    Apr 2014
    South Haven, MI
    That wasnt meant for you blueguy. based on the suggestions here, im just going to run the gen v. I was refering to the unnecessary comment that had nothing to do with the post. I do appreciate the input. Thank you
  11. #11 Re: Gen 3 Gen 5 Hybrid
    I don't even know.
    I can't keep track anymore.
    Anyways you do what you want to do...I just know I've been there and done that. At your mod level, I'd get some bigger injectors and run a 2.6" on that current GenIII and corn feed it. That'd be fun, too. And super simple.
  12. #12 Re: Gen 3 Gen 5 Hybrid
    GXP Level Member
    Mar 2015
    Tomball
    You cannot mix Gen 3 and Gen 5 parts like that. They have a different bolt pattern and the rotor pack installs differently. You could use a Gen 5 snout on a M112 depending on which M112 case you could get. The Gen 5 is more closely related to the M112 than it is to the Gen 3. If I make it by my storage before they close I will pull a couple of M112 cases and a rotor pack to show you what the difference is.
    Jeff
  13. #13 Re: Gen 3 Gen 5 Hybrid
    Kemmerer, Wyoming
    I have a rotor pack that has the gen 5 rotor coating on it in my gen 3 supercharger. it works fine. it probably would have been cheaper to do the gen 5 swap. it didn't require anything special, it installed just like a regular rotor pack.
  14. #14 Re: Gen 3 Gen 5 Hybrid
    GXP Level Member
    Mar 2015
    Tomball
    How did you get the abraidable coating? I know back a while ago that ESM was doing that that was on about 04' or so.
    Jeff
  15. #15 Re: Gen 3 Gen 5 Hybrid
    Kemmerer, Wyoming
    eaton is making the replacement rotor packs for gen 3 that have the coating. I ordered it from zzp, it came in a box sealed from eaton.
  16. #16 Re: Gen 3 Gen 5 Hybrid
    GXP Level Member
    Mar 2015
    Tomball
    How much did that run?
  17. #17 Re: Gen 3 Gen 5 Hybrid
    Kemmerer, Wyoming
    its more than I like to admit paying. it was about the cost of a used gen 5.
  18. #18 Re: Gen 3 Gen 5 Hybrid
    GXP Level Member
    Mar 2015
    Tomball
    So in the $400 range?
  19. #19 Re: Gen 3 Gen 5 Hybrid
    Kemmerer, Wyoming
    yep
  20. #20 Re: Gen 3 Gen 5 Hybrid
    GXP Level Member
    Mar 2015
    Tomball
    I never dealt with ZZP only Magnusen and ESM.
  1. l26 and l67 hybrid.
    By BlackGT97 in forum General Tech Discussion
    Last Post: 05-17-2012, 12:11 PM
  2. m 112 hybrid build
    By zexed99gt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2008, 09:41 PM
  3. Mustang GP Hybrid
    By rfmgtp02 in forum Off Topic Discussion
    Last Post: 11-20-2008, 09:39 PM
