battery is under the back seat in the G bodies. (riv/PA/last gen bonnie's)
you could have dozens of problems, largest is that ground path from the battery throgh the sheet metal of the chassis to the block....lots of voltage drop as the bvehicle gets older and the panels rust at the spot welds/etc.
find the starter relay and see if the problem is on the primary or secondary side....
