Thread: needing some advice 2002 3.8 wont start unless i touch the gas
Results 1 to 5 of 5
  1. #1 needing some advice 2002 3.8 wont start unless i touch the gas
    SE Level Member rc10gt7090's Avatar
    Jun 2011
    minneapolis
    Ok here’s the deal my 2002 gt I have to push on the gas to get it to start. I don’t have to floor it mind you just barely touch the gas. I have changed out the throttle position sensor thinking that was the cuear to what ails it but it is
    still doing it.
    I have looked for vacuum leaks thinking I was on the right path but that was a swing and a miss
    so what else could it be???
  2. #2 Re: needing some advice 2002 3.8 wont start unless i touch the gas
    I'd check fuel pressure. The check valve in the pump is common to be bad. So at key on..you don't necessarily get a full prime, which means you need a little throttle and pump running to get it fired up.
  3. #3 Re: needing some advice 2002 3.8 wont start unless i touch the gas
    SE Level Member midrange's Avatar
    Belleville, Ontario
    when I was having my starting issue, I would have to give it gas to get it going. It was sugested I clean the Throttle Body.. I did, cleared the problem.
    2004 Grand Prix GT1
  4. #4 Re: needing some advice 2002 3.8 wont start unless i touch the gas
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    id do what bill says or replace fuel filter to see if that helps. its only 10 bucks and theres nothing wrong with ever having a fresh one on.
  5. #5 Re: needing some advice 2002 3.8 wont start unless i touch the gas
    Jun 2011
    minneapolis
    found out i had a broken MAP sensor it was always reading the same pressure. nevor changed
  1. I'm Stumped-Needing Advice
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2011, 09:37 PM
  2. 2002 GP won't start
    By scoob in forum General Tech Discussion
    Last Post: 01-28-2011, 12:42 PM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. I have a 2002 gp gt need advice on mods plz!
    By 2002gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2010, 05:01 PM
  5. 2002 Grand Prix Gt issues, need some expert advice
    By gtpx02 in forum General Tech Discussion
    Last Post: 06-10-2009, 11:19 PM
