Thread: simple question
Results 1 to 8 of 8
  1. #1 simple question
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Since i cant brain today. When pulling the Harmonic Balancer, does a seal need to be replaced or can i just put it back on?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: simple question
    leave the seal, put the balancer back in.
  3. #3 Re: simple question
    St. Louis
    NOOOOOOOOOOOO! Don't do that! You'll let the "magic smoke" out and you'll be forced to buy a minivan.
    seriously, Scotty is right. We've all had those "no brain" days. All you MUST do is be sure that the woodruff key on the crankshaft lines up with the slot on the balancer when you go to reinstall, or bad things can happen.
  4. #4 Re: simple question
    Apr 2014
    South Haven, MI
    And the bolt size for the HB removal tool is 1/4 by 28 Right?
  5. #5 Re: simple question
    the bolts for the balancer to the puller. they are metric size is in this thread. http://www.grandprixforums.net/threa...a-crank-sensor
    M6 x 1.00 and 70-75mm
    pretty sure i used 55 mm long and they worked well with it in the car. if you cant find them i have a bag here. i had to buy a bag of 25 bolts. no one had them local long enough.
  6. #6 Re: simple question
    Apr 2014
    South Haven, MI
    Ok cool thank you. Ill stop by my local menards and pick up a couple.
  7. #7 Re: simple question
    you need 3 of them and some washers to keep the heads from pulling through the puller.
  8. #8 Re: simple question
    GXP Level Member
    Mar 2015
    Tomball
    Hopefully you won't end up with a balanced that has the holes but not tapped like I did. Ended up tapping them 1/4-28 because that's what I had.
    Jeff
  1. simple differential question
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-12-2014, 06:35 PM
  2. simple question
    By Below Average Joe in forum General Tech Discussion
    Last Post: 10-18-2011, 12:32 PM
  3. Stupid Simple Question about keys
    By mwzeigler in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2011, 07:45 PM
  4. simple plug question here
    By clevelandfan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2010, 05:14 PM
  5. Simple Oil Change question for you do it yourselfers....
    By Iron Indian in forum General Tech Discussion
    Last Post: 12-24-2008, 10:31 AM
