Thread: simple differential question
Results 1 to 11 of 11
  1. #1 simple differential question
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Some of you know that I fried my diff. So I'm getting one from the jy. My question is can I take any differential from any hd trans? I found two +04 grand prixs that have the gen v. so there fore they have hd trannys. Will they work? Mine has 34 teeth so it's 3.29?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: simple differential question
    Willoughby, Ohio
    I have swapped a diff from a regal to a GP, they were exactly the same minus the speed sensor connection was different. so my guess would be as long as you find a HD tranny with the correct gears, it should fit. just keep your VSS handy
  3. #3 Re: simple differential question
    Orland Park, IL
    So if the sun gear has 34 teeth and the other side has 30 than I'm good...? What is vss?
  4. #4 Re: simple differential question
    Oct 2011
    Toledo, OH
    Quote Originally Posted by m17davis View Post
    What is vss?
    Vehicle Speed Sensor
    7"
  5. #5 Re: simple differential question
    Orland Park, IL
    Sweet. Thanks. Do you guys have any easier methods of removing the passanger axel?
  6. #6 Re: simple differential question
    Unbolt stuff and either yank it out or get a pry bar in there and 1 swift move and it'll pop right out.
  7. #7 Re: simple differential question
    Willoughby, Ohio
    yup, big pry bar and a swift motion
  8. #8 Re: simple differential question
    All HD diffs are 3.29 in a 4T65 trans. Make sure you put the sun gear in the correct way and you'll be good.
    ATSG manual says to put a big screwdriver or wedge in there and give it a whack... it's all good as long as it's a fast hit to make the compression ring compress.
  9. #9 Re: simple differential question
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    Not saying youre wrong, but arent the GTP's and GXP's HD diff's? which are also 2.93
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  10. #10 Re: simple differential question
    HD's are all 3.29 diffs. The 2.93 is created by using a 33/37 drive/driven gear/chain setup at the other end of the trans with a 3.29 ratio diff. When you divide 3.29 ratio by the chainset 1.12 you get 2.93.
    GM calls the diff the final drive which I originally found confusing. I was thinking final drive ratio was the overall ratio. It isn't.
  11. #11 Re: simple differential question
    Jan 2012
    Dyersville, Iowa
    and I apologize for thinking you were wrong. fwd trannys always confused me with the layout, rwd just makes more sense to me and I have 100x more experience with rwd
    -SOLD
  1. Differential question
    By Raviaan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2012, 09:24 AM
  2. simple question
    By Below Average Joe in forum General Tech Discussion
    Last Post: 10-18-2011, 12:32 PM
  3. Stupid Simple Question about keys
    By mwzeigler in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2011, 07:45 PM
  4. simple plug question here
    By clevelandfan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2010, 05:14 PM
  5. Simple Oil Change question for you do it yourselfers....
    By Iron Indian in forum General Tech Discussion
    Last Post: 12-24-2008, 10:31 AM
